Exactly my thinking, yet the last time I mentioned this, I was told by a Busse fan:
Now that I know at least someone sharpens INFI to a reasonable thinness, I suppose this means it can actually take it... I have seen many knives by top end custom makers that fail chopping Maple even at 15 per side (and I mean fail in less than 20 strokes): A big RJ Martin in S30V would do micro-folds (a very modest failure that could be detected only as a tiny sideway fold that barely grabs the nail material as your rub the nail, but still unacceptable for ONE hit...), an ACK in 440C at 12 degrees per side (heavy curling), and another 440C knife by Vaughn Neeley, also at 15 degrees per side (crumbling).
Knives that held up included Randalls, Colin Cox, Al Mars in Aus-6 and especially 2 Liles (unmarked if D-2 or 440).
Nice to know then that INFI can actually hold up at useable thin angles. I never could understand anything over 15 per side... Even 15 is really the outer end, more like a good dagger's angle.
Gaston
One way to run narrower edge angles without trashing the edge is to put a microbevel on it. So profile to 12 dps, but then finish with a 15 or 20 dps microbevel.
I keep challenging Trolls to put their money where their mouth is --- and they cowardly remain silent. If you're having trouble cutting or chopping through things with a 20 degree (40 inclusive) edge angle --- you need to go get an X-Ray and then see a specialist for how brittle your skeletal structure is. I sharpen/reprofile edges to 19 degrees per side (38 inclusive) for most of my knives and I wail on them as hard as I please without needing to steel or sharpen for many outings. I'm no guru --- but I certainly know what I'm talking about and my edges turn out just fine
I WANT TO PROVE YOU WRONG ---- I challenge you -- do you accept??
I think you may be misreading Gaston. He seems to like narrow angles as do you.
Um, really???It IS excessively low, and that is one of the craziest things I've ever read here. INFI / SR-101 at 58-60 Rockwell C does not have enough stability to support that thin of an edge under heavy use without some pretty serious edge damage.
Maybe at 62-64 RHC, but then the steel will begin to chip out under any amount of lateral force. You WILL get edge rolling and eventually tear-out with that kind of geometry if you try to baton and/or chop with it, especially on hardwoods. A 20-25 degree edge (inclusive) will hold up under a lot of others kinds of normal use, but not the kind of heavy usage that you're talking about (chopping and digging).
How do I know? BTDT. I sharpened my custom shop Bowie RMD to that kind of edge, and in bit of a drunken chopping session one evening, chopped up a bunch of seasoned Red Oak. The next day, once sober, I was shocked to find that my edge was pretty well trashed. No chips or tear-outs, but it was pretty rippled along nearly its entire length, and I couldn't fully repair the edge by steeling it back straight, Instead, I had to grind away some steel to get it back to normal, and reduced the included angle a bit to ~30 degrees while I was at it.
And below 20 degrees included???Come on man, seriously?
Maybe if you're using you Busse as a sushi knife...
Even many razors are set to a final edge angle of 30 degrees. A ~15 degree straight razor will even have a final edge angle of 25-30 degrees due to micro-convexity after stropping. Don't believe me? I suggest you take a gander at the Science of Sharp. There is little reason to put an edge less than 30 degrees inclusive on a knife much larger than 4-5", especially if it is expected to see hard use. Even in general, at less tan 30 degrees on most steels, the edge is either going to get damaged, or you are going to be sharpening it all the time.
[In reference to using 12 degrees per side on INFI]
Seriously?
This is a 440B Randall Model 12 after over 1000 chops in year-old dead dried Maple: Edge angle is around 10 degrees per side on an extra thin 0.020" bevel (knife was laid almost dead flat to the hone). No visible damage to the edge at all...:
If INFI can't do the same, then INFI is just another inferior steel like many others...
Frankly the mention of a "drunken chopping session" is not exactly what we hope to hear as an objective and valuable evaluation of what a steel can do...
If you can't believe that 12 degrees per side is plenty enough for any decent steel to survive chopping years old dried-out wood (Maple in this case) a thousand times over with no visible damage (even with the bark not stripped to remove dirt particles), then just accept you don't own good enough steel yet, or that chopping in a drunken state is not the best idea... I don't even know why you would bring up that "test" as an example...
Gaston
welp.... now that we've all come to a consensus.... could anyone recommend a good small field strop to maintain the couple blades that I have with factory convex edges?
Leather belt with green compound on the fuzzy side
Wow, always loved your edge shots, but did you intend to broadly characterize everyone here who prefers a lower angle than you as some kind of cowardly pussy?, b/c that's what it sounds like you just did.![]()
