I wonder what performance gains we would see from an INFI machete over, say, 1055.  Noss’s 1055 Cold Steel Kukri Machete (about $25 with sheath) almost did him in—couldn’t kill it with anything short of lateral stress, which no 1/10” thick blade is going to withstand.  That 1055 is left soft on a machete—probably in the 50 HRC range—so it won’t hold a clean, sharp edge for long.  But the blade is so thin to begin with that, for it’s purpose, it doesn’t have to be razor sharp to work.  And when you do need it really sharp, it’s easier to sharpen quick than just about anything you could name.  Which means it’s also quickly restored after picking up incidental edge damage—obviously that’s going to happen often with a long, thin blade swung hard into all kinds of stuff, including the ground (which has broken 1311’s as reported here on the forums).
So what more would you get from INFI—less oxidation and a little better edge life (until its first ding)?  For what cost?  Is it worth it?  You know Jerry has thought that through, given the level of interest over the years.
BTW, thin SR77 doesn’t appeal to me after seeing how the edge on Noss’ (very thick) test blade looked at the end of his test (compared with INFI blades he tested).  It was chewed up almost to the point of being unrestorable without a full primary regrind.  SR77 is very tough, but it’s not very strong (relatively).
