Shotgun said:Neither. Busse's are too expensive for what you get and the only ESEE design I like is the Izula 2 but I already have a better knife for that niche.
Please state your preference and why between the following two knives:
- 'Busse'
- 'Randall's Adventure & Training ESEE'
.......and no one but another Busse fan boy even knows what all those letters mean when a proud owner mentions their various Busse blades.![]()
- 'Busse'
which models?
On the Busse side of things, their Basic line handles are some of the most comfortable I've ever handled.
many of the patterns tend to thick blades and there have been complaints about obtuse edges on some models.
the heat treat is impressive -- and that's most of what you're paying for along with the name.
great warranty & resale values.
ESEE - 1095 is what you get -- coated for rust/corrosion resistance. coating can be removed chemically fairly easy if that's what you want.
I really like the izula 2. I also like the 4 with aftermarket scales and the 6 as it came -- fit my hand perfectly.
excellent heat treat.
great warranty, holds their value fairly well on the resale market, value does not go up like it seems to on a Busse.
There have been several chopping comparisons between the ESEE Junglas and the Busse Bushwhacker Mistress (BWM) that generally end up in a fairly dead heat for function.
Busse has more variants, but they only come in limited runs.
ESEE keeps costs down by only producing a limited number of models/variants.
before I can tell you which is better, i need more info about what comparison you want made.
how are you going to use the knife (do-all hiking/camping knife, food prep, chopping up trees, etc?)
what size blade do you want?
are you including Busse-kin? (Swamp Rat & Scrapyard)
do you have a price range or is this a "hypothetical if $$ was no object" kind of question?
I thought the choil was a waste of space, too. The handle on the ESEE-4 I had was too short, unless using the choil. So why not use that choil space to instead simply extend the handle to make it usable at all times, and not just when uncomfortably choking up? The handle on my ESEE-6 fit better, but the choil was basically useless for me. Got in the way far too much while wood working. I'd rather have an extra bit of blade there extended right down to the handle than useless choil space. If the blade came to the real handle, you wouldn't ever need to choke up in the first place...
