Busse, Winkler, Rmj, many Customs
Feedback: +217 / =0 / -0
Links to original threads and pics, too many pics to post in this thread.
http://www.bladeforums.com/forums/showthread.php/1268387-Busse-Winkler-RMJ
http://www.bladeforums.com/forums/s...ellite-6k-Crawford-hawkbill-2Rmok-Fixed-Blade
http://www.bladeforums.com/forums/s...-Fairall-Crawford-and-Daniele-Serrano-flipper
1. Busse MOAB- Midnight camo blase finish, black and tan g10 scales. Slight smoothing of the finish due to sheath insertion. Comes with an open spine kydex sheath with lg. tek-lok.
2. Busse MOAB-Black crinkle coating, hand sanded black linen scales. Sterile, stainless steel smooth bolts. .31" thick. New from Busse.
Trades for the MOABs
Spyderco para2- multiples, sprint run plus cash
Medford plus cash or multiples
Busses- fbm, ffbm, nmfbm, TGLB, AALB, Nm of all kinds
Hinderer plus cash, multiples
Strider plus cash, multiples
Winkler ii plus cash, multiples
RMJ tactical plus cash, multiples
Sniper Bladworks plus cash, multiples
Direware plus cash, multiples
Mummert Hawks plus cash, multiples
3. Winkler combat axe- Black micarta scales, slightly uneven, 5160 steel, caswell finish. Edge has some spotting and 2 flat spots/dings. Unused, unsharpened but has been carried. Pins have coating coming off. Comes with felt lined kydex sheath. Great blade, looking for other winklers. Cash can do either way!
Trade interests are:
Winkler combat axe in 80crv2
Combat hammer in 80crv2
Wild bill in 80crv2
Breaching axe in s7
Sayoc
4. RMJ Jenny wren- Black duracoat blade, black g10 scales. Has not been used or sharpened, has been carried. Has some discoloration on the edge, scratches on the duracoat and a ding in the g10.
Comes with sheath. Great little hawk, looking for other rmj. Cash can go either way!
RMJ S13 shrike
RMJ Kestrel
RMJ Eagle Talon
RMJ Loggerhead
RMJ Berserker
Discontinued RMJs
Custom hawks, full tang, .30" stock min.
Hardcore Hardware Bft01 or LFT01
5. Jimmy lile boot knife doubledged dagger NO DOT- 4" satin blade, stag horn scales, tapered tang. This is a no dot blade. Has lots of fine scratches due to sheath insertion. I have not usedm carried or sharpened the blade. May have been carried, sheath shows some wear. Beautiful blade, wish i didn't have to sell it. Comes with leather sheath.
6. Kit Carson Sm m16- 3" Stellite blade, combo edge. Ti scales, steel(i believe) lockbar insert. I've carried it three times, not used or sharpened it.No blade play in any direction, centered and smooth.
As most know, Mr. Carson passed away in the last few months. He didn't used stellite in many of his blades, this one will go up in value and desirability.
7. Crawford Hawkbill liftlock- 3.5" matte finish hawkbill blade. Frame is one piece of 440c, 1/4" thick, milled out. Extremely sharp, no side to side play, little play up(back), but it's a self defense tool, so the hawkbill is made with a little give so that when it cuts, it acts like a claw. Have carried for two days, few snail trails, nothing big. Only negative is that someone tried to adjust(?), move or swith the thumstud, it shows marring on the lug.
8.Rmok specs:
CPM S30V stainless steel fighter/combat hand sanded to 400 grit
.220" thick
5 7/8" blade
4 3/4" handle
handle material is double layered brick red and black G10
Professionally heat treated by Peters Heat treating to RC60
Cryo treated to -300 degrees fahrenheit
Will come with custom heavy duty hand stitched leather sheath.
Was $350.00, NOW SOLD!!!
Has not been used, carried or sharpened.
9. Rmok specs:
CPM S30V stainless steel fighter/combat knife stone washed finish
.220" thick
6 1/4" blade
5" handle
handle material is double layered black and OD green G10
professionally heat treated by Peters to RC 60 cryo to -300 degrees
will come with custom hand stitched heavy duty leather sheath
Was $350, NOW SOLD!!!!!
Also unused, uncarried and unsharpened.
10.Mel Pardue Auto- 3.75" hand rubbed blade. Red micarta linerless frame. One of the lightest blade i've handled. Few marks on the blade that i caught in pics. Has not been carried, used or sharpened.
11. Fairall Model #3- 3.75" hand rubbed s30v blade. Swedge has 1/4"ish sharpened at the tip. Tan and blue g10 scales, comes with a set of cocobolo scales too. Has extra hardware too.
Detent is on the lighter side. Requires a firm push of the thumb or flick of wrist to open via the flipper tab. It can also be opened with the dual thumb studs. Has been carried 4 times, cut arm hair to test the blade after i sharpened it. Fairall no longer makes knives, so this is definately a collectible. Comes with soft carry case.
12. Crawford Shark 4"- Bead blasted blade, anodized ti frame with ti spacer. I've not carried, used or sharpened. Looks to have been carried lightly by previous owner. Very slight smoothing and a few snail trails on the frame. Very smooth openeing. Solid lockup, no vertical play, very slight play(almost flex) side to side. 95% condition.
13. Daniele Serrano folder #2- 3" satin d2 blade. All ti scales/frame. Comes with 2 blades, bothe very sharp! Ti scales have a few light marks from carrying. It has been carried, but not used or sharpened. Needs a wrist flick to open. Slight side to side play, no up or down play. One of the spacing tubes needs to be flared again, i don't have the tool. Comes with case, COA, 2 blades. Very nice and solid blade, it's too small for my hands or i'd be keeping it.
Trade interests are for #5-13 only, not #1-4
Spyderco sprints
Limited edition Zero Tolerance
Strider SMF- no s30v or cpm154
Strider Fixed in 3v, z wear pd-1 etc. No s30v
Hinder XMs
Sniper Bladworks
Kirby Lambert
Olamic Wayfarer- no cpm-154
Ferrum Forge
Randy Ducette Flippers and karambits
Winkler hawks and blades
RMJ tactical hawks
Swamprat crash rat
Busse blades
BF maker Wenger hawks
Mummert hawks
Brous blades
Custom hawks, both full tang and traditional
Dozier fixed and folders
Some of the pics are blurry, sorry, i'm using a family members camera. More, hopefully better pics on request.
Having said that, pls accompany all offers with pics and specs. EMAIL is the preferred method of communication.
Feel free to throw out an offer, worse i'll say is no thanks.
I reserve the right to do business with whomever i choose.
Thanks for looking!
