- Jan 9, 2011
Thanks Clockworkfish!
The only hole in the tang is for the pivot pin. The back of the bell or cup on the button slides into the tapered groove on the tang. This area looks a little funny because the blade coating has been remove from the wider end of the groove. The groove could have been made with a shaped cutter before hardening or a shaped grinding wheel after.Awesome photos tiguy! I am amazed at how simple that looks. On the tang is the receiving hole for the lock tapered? As in do you think they used like a V bit or something similar to establish the angle?
Yes, Don Robinson wrote up making methods on these a had them published in a small book. USA Knife Maker Supply has them for sale. They are very illegal to make, own, or carry in some places. For sure in Canada. Frank
Button locks fall under the same legislation as switchblades in most jurisdictions. You will not see them named as button locks but are referred to in the law as falling into the category of "gravity knife". The button unlocks the blade and requires no further manipulation of the blade to open (gravity) whereas a flipper, for example, requires a physical manipulation of the blade and therefore is far less scary to the sheeple. So silly.
None of my button lock knives will open by just pressing the button and allowing the blade to fall open...they all have detents.
Btw, aren't small autos completely legal to carry in Cali? I think it's 2" or less...
