C101XHP - Foliage Green Manix2 with CTS-XHP
tazkristi
Spyderco Moderator
Moderator
Now available and shipping... http://spyderco.com/catalog/details.php?product=457
The Foliage Green Manix2 FFG with CTS-XHP is a limited production run of 1000 pieces. The first batch has started shipping through our normal distribution network. The photo is a production prototype and shows a hollow-ground blade, but these are flat-ground.
:cool:
Looks like these will be less scarce than the Smurf blue ones, with a run of 1k.
Now I don't know if I should snag one from the SFO or hope that my knifecenter order goes through...
Gone already!! That was fast
Gone where - Spyderco web store? They only put a small number up into web inventory at a time. I'd be surprised if they're actually sold out. The closeout Bushcrafts went in and out and in and out of stock because of this. I wouldn't panic yet.
:cool:
Thanks for increasing the run to 1K. This gives the collectors a better chance of snagging one. :)
Mine showed up in the mail today and I must say that I'm quite impressed. Fit and finish is top notch. The only flaws I can see (and I have to look very hard and be extremely picky to find anything) are the the blade isn't 100% perfectly centered and the grind towards the tip is not super even. Remember, I was trying to find imperfections and this is all I could come up with. Neither of those affect functionality and don't bother me in the least, as I never would have even noticed if I hadn't tried to look for them.
Out of the box this is probably the sharpest knife I've ever received. I'll put it through some cutting tests (with pictures) and see how the steel holds up. The G10 is insanely grippy, much more so than my G10 Caly3. This is my first Manix 2 and I find it very comfortable in-hand. While I wasn't sure what to expect from the rounded jimping that protrudes from the lines, it feels secure and in no way rubs in an uncomfortable manner. Combine the jimping, InsaneGrip™ G10, and well designed ergonomics and this is one knife that isn't going to slip out of the hand.
I had also been hesitant about the "plastic" cage for the ball lock, but after actually feeling and seeing one I have no reservations at all. It looks good and doesn't feel like a hard, brittle plastic at all. I'm not worried about its impact resistance or cracking. I'm not the biggest fan of the shiny clip, but prefer it to the black painted ones that scratch up easily.
If you can't tell, I'm extremely pleased with this knife and look forward to providing some action shots as I put it to use. I hope that everyone who wanted to get one is able to get their hands on this knife, as it may battle my Sage I for my favorite knife.
I'm not an expert on steel by any means, so I'm not very qualified to compare this knife steel to another. But I do like how razor sharp it came and after doing some cutting, it seems just as sharp as when I got it and it still shaves hair.
As I said earlier, this knife feels great in my [somewhat large] hand. It's very similar in size to the Superhawk handle, with slightly different ergonomics.
I mentioned earlier that the G10 was far grippier than my Caly 3 handle. After putting the two side by side, it looks like the texture on the Caly 3 is slightly finer, with the Manix 2 G10 exhibiting larger spacing between the ridges. This picture shows the texture difference between the two, with an insert of an extreme closeup.
The liners, as noted by others, are skeletonized. I imagine that they must be much lighter than the standard Manix 2, as there's a substantial amount of steel removed. This is a well balanced knife and, while never having handled the non-skeletonized version, probably an improvement over the standard run. Sorry for the kind of crappy picture; my DSLR died and so I'm shooting with my little point-and-shoot. Nonetheless, it gives an idea of the amount of metal removed.
Today was a slow day for cutting things. I started off the morning by slicing some oranges with my Manix 2. It went through very easily. After cutting them, I let the juice sit on the blade for about 15 minutes before running it under water to clean it off. I'm not sure how long some of these steels take to corrode in acidic environments, but the quarter hour in the OJ didn't affect the blade at all. Looks just like new.
Since I didn't really have a whole lot that needed cutting, the Manix decided to get revenge on the USPS box that had trapped it in the dark for so long. To simulate breaking down multiple boxes, I cut it into many small strips. Some sticky residue remained on the blade, but I wiped that off easily with some glass cleaner and a paper towel. The knife handled the cardboard with aplomb and remained razor sharp afterward.
After a whole day of use, I'm still very happy with this knife. I plan on continuing to use it to cut things at every occasion and am glad that Spyderco continues to go out of their way to innovate and bring us these great designs and steels!
Still trying to find one at an online knife store and no luck. :(
Looks like this one might be the one that gets away.
no man, they havnt got them yet. this guy ordered his from spyderco direct. they are making 1000 of em'. If you want one they will be available
