synthesist
So many knives so little time
- Sep 14, 2004
I'd like to try designing on a computer.
Suggestions please.
Syn
Suggestions please.
Syn
A very good friend of mine draws and generates tool paths for a high end furniture manufacturer in montreal. I spoke with him in depth about what type of software would be the best for knife design. He suggested, for the same reason someone mentioned knives drawn on cad/cam look like they were drawn on cad/cam, that Art/Cam or a similar software may be better suited to the geometry that is exibited in knives. Any of you cad/cam wizards have experience or thoughts on what my friend suggested ?QUOTE]
A professional CAD user, using a good CAD system, can develope perfectly organic designs without the slightest hint of "CAD generated" look. There are two ingredients to get there.
1: The styling is more or less worked out before going into CAD. This prevents the computer from driving or influencing the design too much.
2: When you draw or forge or grind something by hand, you are not using true constant radius curves, and straight line segments. So, if you are using a lot of perfectly straight lines, or constant radius curves in your computer based design, you are letting the computer drive the design. This is what NURBS splines are for and why it may be better for a novice to use Adobe Illustrator to develop part shapes than a CAD program, because Illustrator uses these natural looking splines. Splines give better "flow".
Case in point. Look at the knife design above by Jared. No offence to Jared. I like the overall shape and proportion of the design, but the design tool left its imprint on it. All the constant radius curves give it a mechanical appearance that doesn't work well with the overall organic shape of the thing.
Now look at clw3 womamack's design. The varying curvature, smooth transitions and elegant shape are the result of his good eye for design, and are made possible through the use of the NURBS splines used in Adobe Illustrator.
I don't know how much experience he has in Illustrator, but I do know it is common to see people make great shapes like that in Illustrator. I also know it is extremely uncommon to find people able to make shapes like that in CAD. Some CAD is not even capable. For example, unless they've changed it, SolidWorks can not create a curve through points and maintain curvature continuity (C2 continuous) to the adjoining edge or surface. And I'm about sure that AutoCAD can't do it (lousy design tool IMO). Pro/E can, and CATIA can, but there is a big learning curve to get there and they're very expensive.
A final point. The Illustrator design can be exported to a CAM system and profiled into steel.
Thank you for that excellent explanation Nathan. Any experience using any of the Art/Cam type software ? I think Art/Cam was originally developed by MasterCam. -0- experience here other than messing around with BobArt, I'm looking for another opinion. You are obviously very knowledgable and your opinion(s) is very much appreciated :thumbup:
