I have some S35VN. I just ordered another stick. Think about what you want me to try and I will run it with the test blades.
It is a common myth that high alloy steels are more sensitive to temperature than low alloy steels. Perpetuated by those heat treating in a forge to make themselves feel better.
Really ? I m troll ? Just because I learn about pros/cons of different HT oven from books ?You are a troll and will continue to argue. Reading is one thing and doing is another.
That is hilarious to suggest that I am the one that should do more reading. You continue to prove that you know very little about knife making and heat treating.
If you don’t like this thread, then stay away from it.
Hoss
Reading is one thing and doing is another. Really , againRead about atoms is useless if you don t see them , right ? That is your theory ?WHAT about all that thread started your son @Lariin here ??? He collect info from ...wait , from internet .....
What we should say to him ? That he is are troll because he present to us data from someone else ??
I don t want to derail this thread any more .If you like to continue discussing open another thread about HT ovens .....and you can start with data about commercial HT oven from Evenheat ... I have a lot to say in that thread .
This is my last post in this thread ,no more trolling .
Just a quick update. 1084, 1095, 52100, and O1 with standard heat treat are done. I did all of them at 1475f,10 min soak. Tempered in 50f increments from either 300-450f, or 350-500f. I’m going to do more O1 and 52100 with a 1550f soak, cryo, and then temper for comparison. I might do 1095 and W2 like that as well.
I have three more conditions to try with v4e/4v, and I want to try one more with rex121. I’ll send these off then start on the L6, 80crv2, M4, and z-tuff.
I’ve been on a heat treating frenzy lately. I’m spending almost all of my spare time on heat treating as of late. I’m really enjoying this.
JT contacted me and has the samples I sent him. I’m looking forward to the results.
Dude, you are a machine.
Hoss
Pretty soon Warren will be able to run KnifeSteelNerds he’s heat treated so many different steels.
Just a note about my observation of industrial practice is that maybe the machines can be bigger and cost more but the quality is going to rest at the employee level or by what can be automated. I know that I have read plenty of threads about people mapping the heat in their ovens. That's beyond the care of your average guy loading product and using the standard program. I'm not saying that better equipment cant help but that a very caring craftsman is likely producing better results than industrial average.
As I was cutting out the 3v, 4v, V4e, and z-wear, I ran the kiln at 1550f, and heat-treated the L6, O1 with cryo, and 52100 with cryo. Tempering as we speak. I was going to use 1550f with the 80crv2, but I think I’ll run it at 1525f. I’ll do a couple more conditions with 8670 at 1525 as well.
It’ll probably take me two full days to run the different programs which are shared between the steels. I’ll be using 1925f, cryo, low temper, 1975f high temper (low temper is done already), and 2050 cryo, low temper.
Z-wear will only be at 1975f, cryo, and 300f temper, rather than 400, and 2050f, cryo, 400f temper. I’m trying to get samples to Rc64, to see how much toughness drops above Rc62. At 2050f, three tempers is recommended in the datasheets.
I’m finding I have to follow a process, and be methodical, as running each sample independently would take forever. I don’t compromise protocols, beyond pulling one steel out at temp, while another requires 10 more minutes to soak. Each steel gets the correct pre-heats, ramps, and soak times. Several steels share the same protocols, but I have to carefully label everything, and keep track of what order they get loaded in the kiln, so I pull the right ones at the right time.
Oh, and to address temp control questions, the samples are in small pouches, about 3”x3”, and placed dead center under the thermocouple. I’ve run a separate probe, and my kiln is accurate at that location. There used to be 25f +/- front to back, but it’s about 10-15f (5-7f +/-) at most now as I have steel bars running length wise on each side. Once equalized, temp front to back is pretty even now.
I didn’t feel the need to justify myself previously, as I have addressed this way back when I dialed in my W2 protocol. Didn’t seem like a question a few posts ago, but more like a statement this process was a joke. If anyone knows anything about me here, it’s that I take heat treat very seriously.
