- Apr 17, 2015
I also bought a large amount of A2 and CTS-XHP for testing (and making knives!). I will be watching your A2 results closely.
Thanks for keeping track of who is doing what, because I can't.
Looks good, A2 will not be thick enough to grind however. The 10V is close, that only leaves .009 per side. With slight warping, cutting it close.
Hoss
I’ll order another stick when I do my next order.
Final thickness is 0.984” (2.5mm), correct? What is the preferred starting thickness? 0.110”, 0.120”? The a11 is the same thickness as the z-wear and cru-wear I did before.
.120 is best
Hoss
My a2 is too thin. I can do it at a later date, or you can do it at this time. We’ve been aiming for a range between Rc58 and Rc64. (Rc58, 60, 62, 64.) If you have enough, one transverse sample for comparison too.
So Warren, where did you get 3/16 L6 flat stock?
Uddeholm seems to really like 1975F for some reason. You can probably go higher, and/or temper lower.Does anyone have a recommended heat treat for vanax? The recommended heat treat is 1975f, quench, and temper at 390f. This results in Rc59. I’ll do this tonight. If there is a protocol for Rc60, or Rc62, I’ll do that as well.
