I believe Warren did samples with 1975/400F and 2000/400F. Can always do more heat treatments of course.Anyone have vanax in the works? If not happy to send material
I was looking for it in the chart missed the to be done list my bad.
Warren thoughts on vanax compared to z wear?
There is a new toughness champion: 8670 with 400°F temper gave 59.7 Rc and 51 ft-lbs. The 175°F temper gave 63.9 Rc but a drastic reduction in toughness to 6.1 ft-lbs, lower than CruForgeV at the same hardness. M2 was similar with 6.2 ft-lbs at 64 Rc, difference between 400 and 1000°F temper was small but 1000°F was slightly better (5.4 vs 6.2 ft-lbs). 52100 was 19.7 ft-lbs at 61.9 Rc (1475°F-300°F), similar to CruForgeV. N690 the worst steel yet at 3.7 ft-lbs though heat treated to 62.6 Rc with likely too low temper of 175°F. Z-Finit keeps giving me high variability in toughness testing for unknown reasons, it got 27.8 ft-lbs at 59.5 Rc but the scatter was extreme.
It could be that it reaches yet higher toughness at lower hardness. However, the toughness at ~60 Rc was very impressive. I haven’t seen so much deformation in other steels.
I’m not surprised! It tested as one of the best from what I’ve done so far. That steel is extremely tough stuff. Ztuff will definitely unseat it though! I made a warranty replacement blade for one of my friends, he works at the mine here where I live. He broke a through hardened blade in 15n20, cutting through some mild metal with a small hammer, snapped the blade in half. I replaced it with 8670, tempered at I think 375, with the spine drawn back. He has yet to break this one!! Larrin, was this one austenized at 1525?
That’s the tempered martensite embrittlement range where the dip is. There is usually a peak in toughness around 400-450F and then you have to get past the TME region to further increase toughness.I found a chart from Crucible for Champaloy that seems to show that "dip" at 59-60, Their numbers said the 400F temper would give you that 61 or so and a Charpy notched reading of 43 lb ft. At 500F, which was 58-60 Rc, it was down to 37 lb ft, but at 600F they said it was at 56-58Rc and 58 lb ft. Interesting stuff.
It certainly doesI was under the impression that L6 did not suffer from TME.
Where is the updated table,It certainly does
