Willie71
Warren J. Krywko
- Feb 23, 2013
The main thing I can think of would be a low temper with no cryo.
Consider it done.
Maybe I’ll try a dry ice/acetone sample too, to compare with cryo.
Warren
If all of our testing yields good results we should have pretty good information on the effect of cryo treatments and upper vs low temper.
Why are we not testing S35VN?If you get odd results on any condition, let me know and I’ll do another set or two of samples. I’m finding this steel pretty consistent from batch to batch. Not quite as consistent as S35VN, which comes out at the identical Rc# every blade, but I rarely see variation above one Rc point.
Ok that’s fine. I’m not trying to make more work for anyone I just figured if you had it we should test it. It’s a pretty common one, after all.I don’t have any thick enough. I can add it to my list with 3V for my next order.
Warren
US Steel has them but I don’t. A good OES is very pricey.Larrin, do you have access to a steel analyzer? I have a vintage grader blade that I would like to have tested. I was quoted $250.00 locally.
What would be interesting is forged vs non forged tests lol
All steel is forged unless it is as-cast.What would be interesting is forged vs non forged tests lol
But drop forging/closed die forging is supposed to increase toughness even more, due to grain orientation, correct? If everything is equal, steel type, heat treatment. I hope I’m not opening a can of worms!All steel is forged unless it is as-cast.
We are using longitudinal samples, which has the highest toughness. Other orientations would be worse.
