https://youtu.be/mtkOxbbeafo
Here is the video i made it took all night to upload to youtube, here it is running with different belts of different manufactures, Teppojutsu you mention repeatedly in your posts it may be assembled wrong, cant happen, why you ask, because it comes assembled the only assembly there is is 4 bolts to mount the motor, 6 bolts to mount the vfd and vfd bracket, and to tighten the drive wheel set screw in which every wheel is pre fitted to the motor shaft and comes with a spacer block to set the correct offset to the tracking and flat platen wheels, and its completely pre wired, at the end of the video i show measuring tracking wheel and flat platen wheel spacers i had my arms wrapped around the camera and tripod a bit awkward, there are no washers or shims to adjust spacing, and just in case you are not sure about increments on a micrometer the last number is in tenths not thousandths, if you look at the way its made its pretty hard to mess it up, I have seen belts a lot worse than those videos, as for not enough belt tension we have run jflex high grit belts (thin backing) and they have never cupped like the one in the video, our drive and tracking wheels have low crowns you dont need high crowned wheels if your machine is lined up properly, in previous posts you asked for audio of the belt running, different belts make different noise levels if you want a quiet grinder put rubber coated wheels on your flat platen wheels and you wont hear the tape joint as much.
As for the grooves cut in our drive, tracking and platen wheels first off they are only 0.012 deep two and a half times as thick as a human hair, they are perfectly spaced and their purpose is to allow a little air between the belt and wheels surface they do not affect tracking whatsoever, we have made smooth ones also no difference, on the tracking wheel the two outside grooves are visible with the belt running and a perfect way to judge if the belt is centered perfectly.
In the two treads i have seen you started you want people to compare the Northridge grinder and the TW90 his comes with rubber coated platen wheels and an adjustable belt tension system and a long track record of high quality and great customer service seems to me you would be best served to purchase a TW90 and alleviate any lingering concerns you may have about our product.
Thank you George
