Can we talk about crinking?
You can tap the bolster in front of the pivot pin on the side needed to move the point when closed. But it's best to have a dead straight, flat & parallel blade, frame & spring to start.
I had an issue with 1/16" thickness springs bowing in heat treat, then i rebuilt my kiln so i hang the parts vertically and in the center of the oven. It virtually eliminated the warping and solved a lot of my centering issues. The main things now are holes drilled straight, blade ground evenly, and when fitting and gluing scales i have to make sure the fit isnt so tight that the scale and liner have a small gap near the ends. I clamp the scales and liners to a piece of hardwood with a good planed surface (covered with saran wrap) and inspect the bolster-liner-scale joint to ensure it is gap free. If there is a gap or i dont clamp to a flat surface while glue is drying it will cause centering issues.
