Take scale off , find some piece of round steel in same Dia. as hole ...cut it in same thickness as thickness of tang . Mix some epoxy and put it all together .I bet that handle will be stronger then beforeWell, I messed up.
The idea was to baton it into a stump to straighten the tip first. And after that cutting a line into a stump with a saw, and then putting entire blade into that cut and bending it back to straight.
The snap happened when I tried to baton the tip of the blade into a stump, I used a piece of wood as a baton but it was very surprising.
Other thing that surprised me was the place where the crack happened. I expected that if snap is going to happen - it will happen near the first screw that's closest to the blade.
For some reason they drilled a hole the part of the tang that has no screws, and that same hole was structural weak point that in my opinion shouldn't be there.
This knife has been through a lot and I don't mean to bash on it, it's extremley tough for what it is, but again - there's no justified reason for tis hole to be placed here either-
That's good manA bent knife will cut circles around a straight-bladed knife any day. Is it now right-handed or left-handed?
LOL !!! That's the spirit! Left handed or right handed... still chuckling.
I have my personal Cutlery that I carry all the time and use all the time, and that even extends to the kitchen.
The love of my life had no clue how serious I take my cutlery. After a couple of times a finding my kitchen knives in the sink with plates, dishes, and pans on them, I decided it was better to keep her than squawk about $100 knife.
I bought her two kitchen knives that belong to her and are for her use only. My knives are off limits, no negotiations.
That was fine with her, and the problem was solved. You should get that Boker back in shape and kiss it goodbye.
Robert
YesTime to get her a Busse
And the cool thing is, if you break it, they’ll usually replace it.Get her an Esee, so she can abuse de hell out of it. Or just give her the Esee 5, she wont bend that one
One edge near that hole was in different texture and color as can be visible on the pic, it was rather smooth, and rest of the crack is grainy.that hole was put in to save weight... it's fairly standard
I'm a bit shocked that it broke there, since it's really quite thick & the hole is rounded so there should have been no direct stress risers
Maybe the tempering was 'off' or missed in some way?
True, but I still have a feeling that it wouldn't crack if it wasn't for that hole there.that hole was put in to save weight... it's fairly standard
You're right, those edges wgere the crack happened are very sharp, I'm lucky it didn't happened in my hand.It’s always disturbing to see a knife turned into a finger guillotine. Glad no one was hurt. The crack could have been already there from the past throwing.
Knowing her - they'd have to keep sending her a knife after a knife...And the cool thing is, if you break it, they’ll usually replace it.
She will singlehandedly force ESEE to rethink their policy LMAO.Knowing her - they'd have to keep sending her a knife after a knife...
LMAO hahahaha, they would maybe have division just to make knives for herShe will singlehandedly force ESEE to rethink their policy LMAO.
