- Aug 27, 2004
This is a picture showing a catch-bit on a single spring canoe. The catch-bit is half the thickness as the backspring and the same thickness as the blade tang in this instance. This allows the blade that pivots on the other end to be full length and still clear the full width of the tang. The clearance arrow shows the difference between the size of the catch-bit and the size of the blade tang. In this picture the backspring is positioned about were it would be as if the blade was installed.. As Tony Bose and Kerry have stated , this clearance is needed to allow the backsring to rest on the blade tang and NOT the catch-bit, and to allow for any wear in the tang and spring. Of course there is a catch-bit on the opposite side frame, other end. Its hard to see the blind pin as its been peened and leveled. Second picture shows how the blade will be in the closed position(close anyways!).
I hope this helps clear up some of the "mystery" of a catch-bit!
