I wonder if why some people are better at sharpening than others is fine motor skills. As I said, even going slowly with the Sharpmaker, I am NOT completely consistent. As I said, I can vary being between hitting the entire primary bevel (which on this side is about 1/4" wide) and coming within about 1/100th" of the edge. I just now tried a few passes with the 40 degree diamond rod and it was hitting about half that width of the edge. It was also beginning to produce a burr, I think.
So, if I slop around that much with the Sharpmaker, I'm always going to produce sub-optimal results compared to someone with a more steady hand. If I keep on at 30 degrees, I will just slop around too much to get the desired results. Perhaps the answer IS to make a few strokes at 40 degrees to get the burr and then switch to the other side. Thoughts?
