- Jun 11, 2006
After my last post about "burning" the oxygen in a heat treat oven I have been doing some testing. I first tryied using it at high temp with foil to see if it helped prevent foil burn through. It seamed to help to an extent, by that I mean I was not burning through foil anymore at real high temps. Next test was on some 15n20 and it also showed a great improvement on surface scale. The final test was on an actual knife and after a conversation with a customer I decided it was time. He hand finishes his blades and had problems removing the little circles and lines that come from scaling. So he sent me a small blade that looked just about finish sanded and I figured no was the perfect time to try and save his finish.
I heated the oven to 1475° and once the oven was at temp I tossed in a charcole BBQ Briquette and closed the door. After a few min I opened the door and the charcole caught fire and I put the blade in the oven and closed the door. Once the oven reached 1475° again I gave it a soak 10-15min. I then opened the door and the briquette caught fire again and I snagged the blade and quenched in parks 50. After wiping off and cleaning I noticed there was no scale just a even pitch black smooth finish on the blade. I can't feal any pits or finish issues. I then tested the hardness and from past experance any carbon steel that gets a soak has issues with hardness testing without grinding a spot to test. Well the tang of this blade tested at 66-67rc over a few tests. It then got a temper and is sitting at 61-62rc now.
I can't be anything but happy with the results and I will continue to test this to see how this continues to work out. Here are some pictures.
