Bastid said:
Queen D2's come with a very obuse angle. You have to have actually seen one to understand that it is overly obtuse.
My folders are typically ran at ~5 degrees per side, and thus I see almost everything as obtuse, I am familiar with reprofiling an edge. I have done it on many D2 blades, both customs and productions, and on steels which are far worse to machine, including ceramics and on blades which are far thicker and more obtuse than and Queen folder.
Reprofiling a small D2 blade would not take very much time if efficient stones were used. It would be a few passes on a belt sander, but not much more than a few minutes on really aggressive hones were used, either a decent SiC+lapping compound or a pseudo-file made from a 80 grit sanding belt. Clamp the blade or benchstone and use heavy pressure and the steel will fly off.
Reprofiling is only really an issue time wise on very large blades with very thick edges (as in 1/16" thick) which thus require massive amounts of steel to be removed. I doubt the edges on the Queens are much more than 0.025" thick, thus even if they are obtuse the cross-section is small.Of course if you try to reprofile on a v-rod it takes hours, but wrong tool.
But again this isn't a steel issue, it is a profile issue. The blade is hard to sharpen because of the way it is ground, not the steel. D2 sharpens easily to a crisp edge when the knife is ground so as to optomize its performance for D2. A well ground D2 blade would be easier to sharpen than a CV blade with a horrible profile. If both are ground optimally, it is inconsequential with either assuming efficient use of abrasive grits and micro-bevels.
-Cliff
