- Jan 5, 2005
BTT I've never made a slipjoint. Now is good a time as any
Deker, when you're ready for surface grinding let me know. I'll do it reasonably (free)
PM me & I'll give you my addy.
This is great and the timing couldn't be better. I've been collecting coke bottle slipjoints on ebay for the past few months. The last two were Henery
Sears with worn blades which I got for relatively cheap and made my own blades. I've been trying my hand at slip joints on and off for the past few weeks and keep gettinh hung up on the springs. Just keep breaking the damm things. I haven't managed to get the temper right yet. I'm using O-1. Anybody got any advise on how to temper to "spring hardness"?
I've printed this out and it'll be my next project. I'll post it if I can get past the tempering issue and actually get one completed.... Since this is pages back I'll post the temper question seperately.
Thanks for the inspiration and the great plans. I Love the symetry of coke bottle designs and can't wait to make myself an EDC thats all my work.
Ed
Sorta on topic, I have a question for you slip joint makers. How do you peen the pivot pin so it's tight and blends well with the bolsters, without making the blade too stiff? I realize some use bushings to get around this problem, but would like to know what you guys do if you're not using a bushing? I've had some problems in the past where there's still a dark line around the pivot pin (i.e., it's not invisible).
I've used extremely thin metal spacers while I do the peening, which were removed afterwards. Now I'm thinking about just using a piece of paper or some type of plastic sheeting I can melt out with a solvent as a spacer. Any tricks you can share?
To keep from having a visible line around the pin after it's peened, you need to clean the pin up with light sanding. Any dirt around the pin will cause it to show up after peening. The pivot hole in the bolsters should be tapered with a 10 degree reamer so that the pin spreads out into that and gets a good grip on the bolsters.
You can relieve any over-pressure on the blade after peening by taping on the corner of the blade at the tang while holding the knife handle at 45 degree angle.
I have heard of making very thin shims(.001-.002" thick) with a slot in it to go past the pivot pin. That is slipped into place for peening.
Yeah, I sand the pins... But the countersink should only be 10 degrees? That may be my problem then- I think the bit I was using is probably closer to 20 degrees. (making the countersink deeper, as PCR said.)
Not quite following you there, man. You're tapping with side pressure on the spine, or kick, or something? Any pictures of the process?
Yeah, that's what I was doing. My feeble possum brain couldn't remember the word "shim", so I wrote "spacer" earlier.I have no experience with the bushing method, but am pretty sure I wouldn't be able to make them work very well for my application. And, after all, some darn fine pocketknives were made for centuries without 'em.
The wider you make the countersink, the bigger your "peenage" needs to be. Maybe your peenage isn't big enough![]()
I just took this image(below) and is the best I could come up with. This is called "slackening the pivot" and is just an easy way to spread the bolsters away from the blade. Something more solid than a book would be under the kick as you tap the opposite edge of the blade with non-marring hammer of some kind.
