Don't be flattered, I don't save your posts. I just happened to run across it when looking for EP vs. WE threads.
cbw
If you say so... :jerkit:
Stitchawl
cbw
i've never used a WE. they make me curious. however, if i KNEW for a FACT that it was a superior sharpener to the EP, i wouldn't care. truth is the EP is amazing and amazing is good enough for me![]()
With the Wicked Edge you do NOT have to use the small indentations when setting the angle. You can turn the adjuster around and use the smooth side. That way it is infinitely adjustable like the Edge Pro.
The biggest benefit I see in the Wicked Edge over other clamp systems is that it is much more precise and consistent. You can re-mount it much more precisely.
The biggest advatage that I feel the Edge Pro has is the ability to sharpen at lower angles.
If you say so...
Stitchawl
When I first saw it, and saw the video for it, I thought perhaps there might be some benefits in using it. Then I realized it was just another clamp system, a bit fancier than most, but still in all, a clamp system.
I happen to like the DMT Aligner clamp myself. At $9.95 it's a real bargain yet does everything a clamp should do and then some, having lightweight portability for backpacking, versatility to use it with bench stones, sandpaper, and strops as well as its own stones. As I said, I'm sure the Wicked Edge device produces a nice edge. But it's still just another clamp system at higher cost than most.
Stitchawl
For $250 it should be more precise than a $9.95 clamp system. I wonder if it's $240.05 more precise? The DMT Aligner does a damn fine job for something that costs less than ten bucks.
While it does do that, for me the biggest advantage of the EdgePro is that you don't have to clamp the blade if you don't want to, can if you do want to, and still get absolutely consistent edge angles with every stroke.
Stitchawl
Oooooooo way to validate your position.
I don't feed trolls.
Stitchawl
Comparing the DMT Aligner with the Wicked Edge is like comparing the new Schrade Advant-Edge to the Edge Pro Apex.
The DMT Aligner is good, but the two I have both are "warped" a bit from the factory. In other words, one "leg" is slightly shorter than the other. I also get some flex when tightening the plastic clamp down. It works great, but not comparable to the W.E.
I wouldn't compare them. I'd contrast them.
Sorry yours don't fit so well. Mine seems fine. Or maybe I just haven't noticed.
As for trying to compare it to the W.E., I wouldn't expect it to be the same. One is extruded plastic the other machined metal. One costs $250 and the other $9.95. The question remains; is it $200.00+ better than the Aligner?
Stitchawl
Thats a tough one to answer. I guess time will tell. If I end up using the W.E. and get satisfying results then yes, I would say it is worth it.I wouldn't compare them. I'd contrast them.
Stitchawl
Here. Just look under sharpeners then edge pro accessories. I can't link you there because I think it's a violation of forum rules.
http://www.accuratesharp.com/
I have had both the Edge Pro and the WE, I sold the WE, and never regretted the sale.
I like the Edge Pro does avery aspect of sharpening perfect, takes some knowledge of the tool as do all tools.
Great support should you need it.
Made in the USA, not China.
Hand Made in the USA, and signed by the owner of the Co.
Stones are reasonable.
Quality is excellent.
Seems like I buy all new knife sharpeners as they come out, and then after trying them they end up in the bottom desk drawer, The Edge Pro is the one I use. and have for about 20 years, and never a regret for doing business with Ben Dale.
A large portion of the cost for the WE is there adds,
I also waited for stones a long time, backed ordered from China.
The clamp system is hard to adjust with any amount of repeatability, and get the same angle on both sides of the blade, and long knives, forget it.
I kept one part of the WE, the base it's to heavy to reship, I may need a anchor some day, and that would be a good use for it.
gary
I wont be selling my W.E., Edge Pro, DMT Aligner, or my Spyderco and Razor Edge Bench Stones. Heck, I use em all!
If you have been using the Edge Pro for 20 years with excellent results, why do you spend money on other Sharpeners?
gary
You are right, Ben has definitely set the bar with the Edge Pro in a quality product, great customer service, as well as a device and process (a lot of people leave the process part out), in producing one of the best edges you can get on a knife.
The Wicked Edge however, has become one of the first sharpeners to, in some aspects, give the Edge Pro a run for the money. A quality product and process, that produces one of the best edges you can get on a knife. My dealings with Clay, the WE inventor, have been great in regards to customer service.
Like any new company, Wicked Edge has had growing pains. Clay has told me that even he was surprised by the response he's received. They're addressing their growth issues as fast as possible, and have been responsive to consumer issues.
I would disagree that repeatability and getting the same angle is a difficult process. Maybe in the first version this was an issue (I don't know, it wasn't a version I used.) I haven't found this an issue with the current version, and its my understanding it may have addressed some of this. (BTW, if anyone owns the first generation, WE is providing upgraded parts... contact them for details.)
I don't expect the Edge Pro or the Wicked Edge to fit the needs of everyone. But the cool thing is, now you have a choice between two quality products that produce great results, just taking a little different path to get there. So, assuming that you've decided to purchase a quality angle guided system, the choice becomes which one fits your needs better.
Like I've said before, I would have a hard time declaring a "winner". Both should easily meet the needs of the user. The Edge Pro has the ability to sharpen at lower angles. Not clamping the blade allows more freedom in the type and size of knives. The Wicked Edge has a bit of advantage in ease of use, less issue with scratching the blade, and is quicker in getting an edge on a knife.
There are also differences in the stones used, Waterstones vs. Diamond, and their related pros and cons. Some of the aftermarket stones available for the Edge Pro, can be made for the Wicked Edge, so that shouldn't be a concern in the not to distant future.
There's more... these are just a few that quickly come to mind. But the consumer now has a choice which is a good thing. The reality is, there's probably room for both in the market. I honestly don't see a need for it to become a competition, or that one is better than the other. Both work, and the decision should be made on which one best suits your needs... and desires for that matter.
cbw
p.s. If the "anchor" you refer to is the granite plate... there's a lot of uses for it... you can mount your EP on it, you can use sandpaper and sharpen on it, a flat base to flatten stones, check knives, etc.
