- Jan 17, 2008
a smith showed me one day, he's passed on now, it's the same jist and all, but on a larger scale. i believe he said that from a 55gal drum. he was lucky to get a sacks/buckets of charcoal.
here's a pic to help understand.
-You take a 55 galon drum, cut 5 1'' squares in the bottom, and place the drum upon 5-6 bricks, then spread a curb of dirt around the bottom, but not against the drum yet.
-then fill as tight as possible with scrap 2x4's of any length, just packed tight. he did say that believe it or not pine was one of the chearest and best woods to use as it had a higher carbon content than other woods.....just what i was told.
-then he took kerosene and pour it on the wood till it dripped through the bottom. And light. let it continue to burn till all blue smoke (from the kero) was burnt off. but that time the wood should be going good and you can cover the drum with the lid, and put a couple bricks on top, to keep from blowing off.
-then you back fill arround the bottom of drum with the dirt you put there earlier. this will choke most of the air off and cause it to just smolder, but not suffocate it to the point it goes out.
-leave burn till next day, and then open.
He said thats how he used to do it to work in certain shops or reenactments, that required every thing to be period correct, including the fuel they forged with.
SORRY dan if I kinda got carried away, this is just something i always wanted to try, but never got arround to it. Someone might as well use the info.
thanks for not objecting to the post,
andrew
pic
andrew
pic
