Chestnut ridge knife shop, products
Signature Series Updated picture.
Direct Link to Featured Knives & Specials: http://www.chestnutridgeknifeshop.com/catalog/index.php?cPath=82&osCsid=d87e9c52f7e59693bca28ce033f4520c
ASEK WITH SHEATH SYSTEM AND STRAP CUTTER MULTI TOOL
MADE IN THE UNITED STATES OF AMERICA
Brand New In Original Packing
# 1095 CARBON STEEL.
# BLACK OXIDE NON-REFLECTIVE FINISH
# FULL TANG CONSTRUCTION
# MILLED SAWTEETH ON BACK
# BLADE LENGTH: 5"
# BLADE THICKNESS: 3/16"
# OVERALL LENGTH: 10-1/4"
# HANDLES: ONE PIECE MOLDED WITH SPEAR HOLE
# BUTT CAP CAN BE USED AS A HAMMER AND GLASS BREAKER
# DIGITAL CAMO SHEATH SYSTEM WITH LEG STRAP (FLAME RETARDED)
# ASEK STRAP CUTTER MULTI TOOL
DIRECT LINK: http://www.chestnutridgeknifeshop.com/catalog/product_info.php?cPath=51&products_id=368&osCsid=fdf5aeb55d44285f2a43335be4bf3ef3
ONTARIO KNIVES OKC M10 BAYONET
# 1095 High Carbon Steel zinc phosphate finish.
# 7" blade length, 12-1/8" overall length
# 235" blade thickness (1/4")
# Compatible with load bearing equipment
# Fits M16, M4, AR-15
# Handle: Ergonomically designed
# Hard plastic sheath, MOLLE compatible
# Fits M16, M4 and AR-15 Since 1942 Ontario Knife Company is a major suppler of the U.S. Armed forces.
DIRECT LINK: http://www.chestnutridgeknifeshop.com/catalog/product_info.php?cPath=51&products_id=325&osCsid=a2c85f26c416763bf564dd8741e5cc8a
CUSTOM OD GREEN KYDEX SHEATH
FOR THE ONTARIO RAT 5
By: CRKS
MADE IN THE USA
# .08" KYDEX
# BLACK ANTI CORROSIVE ANTI RUST RIVETS
# CUSTOM 2" BELT LOOP
# LANYARD
This well made custom sheath will give you added protection. With superior fit the CRKS Custom Kydex Sheath will hold your knife without rattle and will securely lock your knife in place until you call on it. One hand access makes it easy to deploy your blade.
Direct link: http://www.chestnutridgeknifeshop.com/catalog/index.php?cPath=55&sort=4a&page=2&osCsid=efe037529947255af3a10a7109dc9544
Chestnut Ridge Knife Shop is an authorized stocking dealer for the BECKER BK&T KNIFE. We ship the next day!
Brand New In the Original Box
TECHNICAL KNIFE DATA:
# 1095 High Carbon Steel CRO-VAN Blade BLACK EPOXY FINISH.
# 57-58 RC blade hardness
# BLADE LENGTH: 5-1/2"
# OVERALL LENGTH: 10-1/2"
# WEIGHT: 1.0lb.
# Handle: BLACK MICARTA WITH WITH THREADED BRASS INSERTS AND COUNTER SUNK ALLEN DRIVE SCREWS ON BOTH SIDES.
# Sheath: CRKS CUSTOM KYDEX (BLACK).
# You will also receive the original factory sheath with this knife.
# MANUFACTURER: KA BAR KNIVES
LIFETIME FACTORY WARRANTY
Direct link: http://www.chestnutridgeknifeshop.com/catalog/index.php?cPath=82&osCsid=efe037529947255af3a10a7109dc9544
ESEE KNIVES IZULA KNIFE - BLACK FINISH-
MADE IN THE USA
100% LIFETIME GUARANTY
# Overall Length: 6.25"
# Blade Length (end of handle to tip): 2.88"
# Thickness: .156"
# Steel: 1095 Carbon
# Weight: 2 ounces without sheath
# Finish: BLACK Textured powder coat
# Blade Width: 1.0"
# Grind: Flat
# Handles: None
# Sheathing: Injection Molded, Black (Photo right)
# Pommel: Hole to accommodate carabiner
# Spine: Thumb grippers, .5" long
# Each knife engraved with name, logo and unique serial number
CUSTOM BLACK KYDEX SHEATH
FOR THE BECKER BK9 KNIFE
By: CRKS
MADE IN THE USA
# .08" KYDEX
# LANYARD
DIRECT LINK: http://www.chestnutridgeknifeshop.com/catalog/product_info.php?cPath=55&products_id=893&osCsid=907fe7c881843ea3f83893f32b82285a
ESEE KNIVES (RAT CUTLERY) ESEE-6 (RC-6) KNIFE
Ambidextrous Molded Sheath w/ RAT Cutlery MOLLE System Optional equipment: Jump-Proof MOLLE back
MADE IN THE UNITED STATED OF AMERICA
Overall length: 11.75"
Cutting Edge Length: 5.75"
Blade length (end of handle to tip of blade): 6.5"
Blade Width: 1.56"
Weight (knife only): 11.8 ounces
Drop point blade style, full flat grind
Available in plain or partially serrated edge
Maximum thickness: .188"
1095 Carbon Steel, 57 Rc.
Removable lined Micarta handle slabs
Rounded Pommel w/ lanyard hole
Direct Link: http://www.chestnutridgeknifeshop.com/catalog/product_info.php?cPath=58&products_id=227&osCsid=b9febeeacb6fa7a3fd1d083b6660bdd7
NOW TAKING PRE-ORDERS $175.00 EACH, FREE SHIPPING!
THE DELIVERY DATE IS EXPECTED TO BE DECEMBER 2010 ESEE KNIVES / DPx Gear H.E.S.T. FOLDER
Designed by Robert Young Pelton and RAT Cutlery
100% MADE IN THE USA
LIFETIME NO QUESTIONS ASKED WARRANTY
H.E.S.T. (Hostile Environment Survival Tool)
FEATURES:
Right-hand and left-hand models (Left hand available on request)
# D2 Tool Steel Blade
# Titanium alloy frame lock
# Patented Lion Steel Rotoblock
# G10 handle scale
# Removable glass breaker (comes with replacement smooth head screw)
# Hex-bit driver in handle
# Stainless steel “Mr. DP” Skull Tool adjustment wrench / multi-tool for adjusting RotoBlock, pivot and glass breaker removal tool Standard Paper Boxing with DPx Graphics
# Handle thickness (without clip): .541”
# Blade thickness (Max): .187”
# Overall length (opened / without glass breaker): 7.625”
# Closed length (without glass breaker): 4.38”
# Handle Grip Area: 3.80”
# Cutting Edge length: 3.10”
# Titanium frame thickness: .140”
# G10 thickness: .140”
DIRECT LINK: http://www.chestnutridgeknifeshop.com/catalog/product_info.php?cPath=73&products_id=910&osCsid=a61630dcfa2f1af881796db59e0ab90a
KA BAR 5011 USMC FIGHTING KNIFE
Brand New In Original Box
# 1095 High Carbon Steel CRO-VAN Blade with black epoxy powder coat.
# Carbon steel guard and pommel.
# 7" blade length
# 12" overall length
# Handle: OD GREEN Kraton
# OD GREEN glass filled nylon belt sheath
DIRECT LINK: http://www.chestnutridgeknifeshop.com/catalog/product_info.php?cPath=44&products_id=914&osCsid=7898ccc86a3ca6d55541980d8122433c
