So, what's the difference between a tear and a chip? It's a bit of metal missing one way or the other, yes? I'm asking because I don't know, not to be difficult.
This. After I first got my Fat ASH1.......it was used in a lot of digging work into the ground. I had a factory edge, and after an hour or so, it had a lot of tiny nicks all along the edge just like what's shown here.
I took it to my work sharp for several passes and it cleaned right up. Took it back out for more of the same work and this time, very few nicks. Few more passes on the work sharp. Its been beaten ridiculously ever since and no more nicks or dings.
Beat....sharpen....repeat. After that.......
Beat.....repeat!
I think the common assumption is that a chip is where metal is gone and a tear is still attached. The most damage I have been able to do is when I accidentally jam the tip of a busse into a plate (ceramic) or a piece of slate or something that may be under dirt. The tip can look like mashed clay up close. Then if I smash it with the bottom of a mug or on one of my large cast iron pans it seams to straighten out again with out loosing a lot of material. Infi seams to be both soft and hard sometimes. Maybe that doesn't seem logical, but thats been my experience from both a CGFBM and a satin fatty game warden hack. I don't call that a tear, more a mush?? or mash?? anyway I've cut metal wire and nails without edge damage and the only tears I have was when, like an idiot, I was moving stuff and two INFI blades were smacking against each other.
That sounds like a split. Split, chip, tear, roll, dent, ding...it's all so violent...and confusing...and ultimately, I suspect, irrelevant. Where once was metal, now there is none. At least not metal like it used to be.A chip is when a section of the edge splits, metal isn't lost as much as it is misaligned. Like grabbing a whole pizza and pulling it apart so there is a gap between two of the slices. A tear is when an a chunk of metal from the edge is actually sheared off.
This is interesting. For a couple years I was using my tank buster mostly as a bone cleaver in the kitchen or to chop frozen meat. Then when I finally took it back out to the woods I noticed the edge wasn't performing the way I wanted it too, so I got in the habit of hitting it with a small rod in literally the same why I align the edges of my chef's knifes. Just a few passes on each side once in a while between big jobs. It just seams to get sharper and tougher now and I have never really taken any metal off or changed any geometry. It's becoming a habit with all my knives, but works exceptionally well with INFI.
Just wanted to bump this.
After reading the INFI "formula change" discussion, as well as the factory edge discussion, my curiosity was piqued, and I went back with some minor search foo only to fall into a rabbit hole of great explanatory threads, some going more then a decade back. I don't think it's necessary to repost, but if anyone is curious, it's out there, and needless to say my faith that Busse was, is, and will continue to be, the best possible hard use knives available is unwavering. Just sayin'.
