Chopping 2x4 with thin edge geometry
BluntCut MetalWorks
For my upcoming metal sequencing research experiments, I plan to validate(via inference) undisclosed structure formation volume% within C+Fe system by this test:
Chop kiln dried Douglas Fir 2x4, 3 consecutive times, completed in less than 60 strikes total. Chopper edge geometry at 6.5 degrees per side -- 1 degree thinner angle than a standard straight razor -- and less than 0.008" behind edge thickness. Passing criteria required afterward edge still slowly slice phonebook paper without tear.
AFAIK, currently there is no material can make into a chopper which capable of passing this test. However I don't know what I don't know, hence would like to learn if otherwise. For anyone willing to try this test now until Oct 31st, 1st person video demonstrated of success and send chopper to me for validation. If confirmed, will win/get $500 (pp transfer) as a bonus on top of fun trying.
BLUNTCUT:
must not be anything blunt about your cut..
yeah, where's the video and a closeup of the edge thickness and width?
also, shouldn't this be on the review forum, were testing is done?
Searching for what's possible, especially alien's technology ;) thus not belong in review forum. If shown possible, thereby sort-of-falsify metallurgy strength mutex toughness principle/hypothesis.
lol. ok.
I will tell you, I was sharpening one of my big knives, thinking I was putting 14-15 dps and when I measured I ended up with 8-9 dps. Haven't used it yet, it will be interesting to see how much damage I can do to it.
video?
will be great to see.
Current experiment (sequencing) is still in progress - maybe 7-12 more days to completion. In this batch, the only partial tang 7" S125V blade will give this test a try.
Next experiment planned to has a least 3 10" choppers among these steels [1095, W2, S125V, M398, V4E, ..] These are candidates for an all out attempts.
lol. ok.
Please do a few gentle/tap chops to see how 8-9dps edge fare? Ideally, if existing material can pass this test, I would choose another test objective and save me time & $ as well.
Fun to guess behind edge thickness of this edge.
Given sharpening angle ~17* inclusive, bevel at least 3mm / .118", so BET (2*hyp*SIN(radians(angle/2))) = at least .89mm / 0.035"
Cobalt - what is BET/BTE of this edge?
So thickness BTE, at the shoulder is between 0.052 and 0.054. Towards the tip it gets thicker. Middle of the blade I would say 0.053"
The sides of the edge/triangle are 0.168" near the tip to 0.172" on the sweet spot.
Again, I did this freehand, which is why I totally screwed up the target angle of 14dps. I have another blade that has a wider edge and is 14dps. But because the profile is this one is so thin, it messed me up and I thought I was getting the same rough angle of 14-15.
Preliminary/pilot test to see how close/far current experiment specimen able to chop 2x4 and afterward edge still slowly slice phonebook paper. Per my calculation/estimate before this test - at 7dps, there is 40% chance of a clean pass. TG15 sequence has 60+% chance - a few more days until s125v blade is ready, hopefully hardness reached above 66.5rc.
S125V 67rc, 6.5dps, 0.0038" BET sharpened with edgepro, apexed & deburred at 600 grit diamond plate.
6:08 video
