Wonderful knife
3v, aebl, magnacut, etc... 63-64rc with 6.5dps edge would roll/deform on 1st chop and quickly collapse on subsequent chops.steel with really high toughness should hold up well to this extreme test... it seems much too thin unless intended only for food prep
cpm-3v & aeb-l & magnacut should be near top of list....
s90v and s110 etc I imagine will be too brittle given how thin the spec is
that is honestly one of the worst toughness steels possible... I would be surprised if it didn't chip out immediately if you make it as thin as you say...m398
Actually S125V is the worst on that chart - perhaps only applicable to conventional HT. The pic of experiment results above disagreed to chart extrapolated generalized toughness based on charpy-test. If you didn't watch the video above, please do. A real demonstration/evidence/show worth 1000 'tells'.that is honestly one of the worst toughness steels possible... I would be surprised if it didn't chip out immediately if you make it as thin as you say...
it does not even reach 5 ft-lbs
M398 Steel Testing - Edge Retention, Toughness, and More - Knife Steel Nerds
M398 is a new high edge retention stainless steel from Bohler. I tested edge retention, toughness, and more to see how it compares.knifesteelnerds.com
of the others you listed, none have really high toughness either, so I don't expect they will hold up to 60 chops into a 2x4
of course, I look forward to your results![]()
Agreed, there are variation board to board. 2x6 is 50-60% wider than 2x4, which probably double the chop-strikes/counts due to larger V and chips clearance.Also, one thing to keep in mind is variations from board to board. I have had two boards in a row have completely different properties. I had one board be very hard and the next was normal. So sometimes it's better to use a 2x6 and use the same board for several knives. if possible. If the differences are close between knives, then the board variation could easily be that difference.
Advancement in Material.WHY?
What does/will it "prove"?
Why chop a 2x4 a knife? There are tools designed to cut a 2x4, that are a lot faster (and easier on you) than chopping a daNg 2x4 in half with a knife.
Are you going to build something with 2x4's and chop them to size with a knife? In over 60 years, I've never known someone to do that.
Oh, one of my grandfathers was a carpenter, and several friends in High School became such.
In Vocational Woodshop the class project is/was build a house* and sell it at a profit at the end of the school year.
*I don't know if that school district still offers the wood, metal, machining, welding, auto repair, and drafting regular and vocational (advanced) shop classes
See post #26. I would try 26C3 if my sequencing able to yield above 66.5rc (no luck thus far). I plan to try 1095 & W2, which aim for 67+rc.Did you try your 26C3 yet, that's the best steel I work with currently. If your Spicy white couldn't do it then I can't do better than that.
I super-quench (2 seconds quenchant) all carbon steels.Have you tried a water quench, or brine.
Oh okay.I super-quench (2 seconds quenchant) all carbon steels.
WHY?
WHY?
