So I ust found out. For after months of fretting over the fact that I don't know how to sharpen stuff, I finally had the sense to look on YouTube, and actually found videos on how to do it! It's so easy, I ma no longer intimidated, and I'm about to assemble the "Altoid Can" sharpening kit from the old Tips & Tricks thread. Using the professional edge I got as a foundation (as it was probably intended), I can now build up to a btter edge in one long, "sit-down" session, just like you suggest. But I'll probably try it on my other, smaller knives first.
I was probably a bit less fearful than most of learning to sharpen my own knives - I lived in a small, rural farming village in the Philippines until I was 8 and was constantly around bolos and the the like. I learned how to put a shaving sharp edge on a knife by 12 or so, and only recently (18) got into convex edges. Proper knife sharpening is a skill that anyone who uses knives should have.
I definitely agree that you figure out what you're doing on old kitchen or pocket knives before working on your kukri. I would also suggest learning how to use simple sharpening stones to make a nice V-edge before learning to convex. Convex sharpening is easier in my opinion, but V-edges are more practical for most knives and is just something everyone should know how to do.
If it helps at all, this is what I've found works best in terms of cost effective materials.
V-edge:
220/400 grit double sided stone ($10 max at home depot or a similar stone)
1200 japanese waterstone ($22 off highland woodworking)
strop (I just use an old leather belt)
Convex:
Spongey Mousepad (shouldn't be too hard to find)
3M Assorted Grit sand paper (220, 400, 800, 1000 grits - $5max)
strop (leather belt from above)
Here are also some videos that I found to be helpful:
1) kitchen knife sharpening (v-edge)
2) convex sharpening (he's only maintaining the edge - if you want to MAKE the edge, just do the same thing but start @ 220 and work up to 1000grit)
Oh, I understand that it can't do everything. Kitchen work is only one of several gauges that I'm using to test the blade's edge. But it would be nice to be able to use the khuk frequently, and get more practice, instead of only being able to use it for occasional, heavy-duty tasks.
Ah - that makes sense. I just find too often that people expect too much of a given design and test it with methods that it was not intended for. I definitely agree that it helps to use your knife for a variety of tasks though.
