You are over thinking it. I have knives 25+ years old that are going strong with minimal maintenance.
I always chuckle when I see people obsessing about protection, oiling, disassembling to get lint, water, etc, out.
In about 60 years of messing with knives, I've never taken one apart to clean. If the pivot feels sticky or gritty, a little dish detergent drizzled on the pivot, hot water and a toothbrush have cleaned up everything. I shake out any remaining water (usually) and sometimes leave the knife open on a table to dry for a while. On rare occasions, I've sprayed the pivot with WD-40 to remove any remaining water, followed by a drop of oil. For carbon steel slipjoints, I still follow that practice but for modern stainless steel folders--even the M4 & D2 models--I just shake out the water and let it air dry.
A little rust might form inside the liners of some knives, depending on the type of steel used in manufacture. A little bit of rust is not an epidemic that will destroy the knife. I have some very old folding knives I've inherited that had over half a century of crud and rust present yet once they were cleaned up, they still performed well. Modern knives will seldom succumb to rust unless they're exposed to caustic, corrosive chemicals and not cleaned afterwards. Your Tenacious probably had accumulated your sweat down in the liner and, since you did not wash it out, it caused the rust you found. Soap and water is your friend.
Gee guys- you can scrub your knives with soap and water. If you do, blot/shake as much water out as you can, then flood the knife with Water Displacing 40-WD 40.
It will get into spaces that you can't, and force water out while lubricating and leaving a protective film.
When necessary, I don't hesitate to blast it out with hot water and dish soap, shake it out, hit it with the hair dryer on max, apply mineral oil to pivot and blade, done.
since most of the water my knives see is salt, the fresh water rinse is better for them than the salt would be. plus sweat, plus humidity, its hard on some of them. I also rinse in as hot of water as I can stand, the logic being that the heat in the knife and handle will help evaporate the leftover water. heck, my alox SAKS get boiled from time to time.
I would say that for most people in warmer weather, sweat is going to be the biggest harm to a knife. I was carrying my Case med stockman one day at work, the room we were in was cranking around 35C I was wearing a bandanna full of icecubes around my neck, and my my audio tech who got to sit behind the desk away from the client literally changed into his swim trunks when no one was looking! It was brutal. Point is, that stockman had been oiled the day before, and at the end of the day, all the blades were bright orange with rust and quite pitted. added some character to the blades, after a quick light polish and pantia session. That's an extreme case, but consider what weeks of EDC carry might be able to do.
Not everyone has the same sweat composition, and I'm told that the more people are used to sweating, the less salt and therefor less corrosive the sweat, so maybe that has a factor? I've also found that a coin that I have been wearing on a chain for the better part of twenty years is far more worn on the side that is on my skin that the other side. Who could know?
You've caught me in a generality. In really broad terms, I think sweat is going to be the consistent factor in degradation of a knife. Yes other things will come into play, but in general we think of cleaning blades when they get dirty or used on food. Liners and other things are thought about less so.
Take something simple like a SAK. Pretty tough, not much to go wrong. I've found one in a saltwater tackle box that was locked shut from the corrosion to the aluminum liners. I have an Alox soldier that I found caked in tile grout and the scales are full of pits from the corrosion. Extreme examples yes. But any knife that is stored in a warm, humid environment (a pocket) is going to show some sign of of that eventually, somewhere. Certainly there are factors which will determine the time, materials, person, temp, all that sort of thing. But as a general rule, I think that if you are considering cleaning a knife, and are worried about water in the handle being a problem, my personal opinion is that sweat is far more dangerous to a knife than is regular tap water.
Don't you just hate it when the person arguing with you is just so reasonable? You are right, a little sweat won't do much, and a little rust inside a liner won't bother most people. But for the odd knife knut who feels that any corrosion must be prevented at all costs, well, that'll just give them a little more stress. For the average guy, its worth cleaning with water, rather than worrying about having to dry clean his knife, or wondering which brand of brake cleaner won't rot the scales. just rinse the dang thing from time to time, just like you should with everything else that gets sweaty.
