Australian for Cobra... cabra. ^^^![]()
No problem Chibbi - I am sure there are others here who are more knowledgeable, who will chime in to help also. I'm certainly no expert. The Maintenance and Tinkering forum has a lot of good info on convexing a bladeCheers, Bear,,, some more questions if you please,,,
I'm pretty sure the strop isn't loaded with compound, otherwise that would have been in the add, I guess,,, Chibbi take another look at the add - it says Two Side leather paste, which is a little confusing to me
How do you pre-heat the leather ? (I mean, it's fixed to the paddle) heat gun or hair dryer, just warm it up
Does the sandpaper need to be of the make-it-wet-before-use-type or dry-use ? I use the wet/dry automotive, but do not wet it
Is it normal for the Green compound to be so dry and brittle ? I mean, it falls into pieces when picked up and has some very sharp edges then,,, or did I get stuck with an expired piece or something ? (or do you need to soak it beforehand or heat it or something ?) Does the package say Chromium Oxide? It should have a slight wax base to it to hold it together. Try using the small end, and apply with crayon perpedicular to the leather - use your finger to smooth it out
When do you know it's time to proceed with a higher grit sandpaper ? There is a process where you can use a marker to mark the edge, I will try to locate this link for you - it better describes this than I ever could
what's the best angle to hold the blade at or does that differ from knife to knife ? How can you tell what angle is the best ? I usually start at 15-20 degrees
sorry for the multitude of questions, but I want to get this right from the start and don't grow a bad habbit by doing something wrong,,,![]()
Use hair dryer to pre-heat the leather Chibbi.
To find the angle - lay it flat on the strop - move it while rising the blade - at the point where edge will start to grab the leather (even before its starts to cut it) - thats the angle to strop it at.
