Ankerson
Knife and Computer Geek
- Nov 2, 2002
Sounds to me like you're implying the steel composition might bear more heavily on things like cutting efficiency and edge retention than other considerations, like mechanism of cutting, edge angle etc. I have to admit, I haven't been testing for this phenomena (with all other variables controlled).
HH
That is what I am saying and it is huge, really huge.
Different steels will react differently, some steels cut more aggressively than others do.
High Alloy steels will react differently than Low Alloy steels.
Perceived sharpness is what some people think is happening or what is.
Kinda like a toothy edge, you would get some that will say that is really sharp when they feel the edge and that same edge won't even slice paper clean.
Others will feel a Polished edge that is screaming sharp and think it's dull.
Some steels like the High percentage vanadium steels develop that toothy edge one they start to break down, while they won't whittle hair anymore they are still very sharp and will still cut extremely well.
There is a dullness curve and that will change depending on the steel and how it's sharpened.
Some steels are pretty flat, they just keep getting duller at a continuous rate so that's what I mean by flat.
Some steels have more of a dullness curve to them, they will start to dull, then level out for a long time before finally lose their edge completely.
Most people wouldn't see this unless they are testing a lot of steels with strict measurements using the same media, edge angle, finish ect. There has to be a starting point and an ending point and those measurements have to be the same for all blades tested.
One just can't take a knife to work one day and cut some stuff they happen to cut that day and call that a test. One day will be different than the next, there has to be some method used, the variables have to be addressed.
That same blade might work great one day, then the next day it might suck, the following day it might be great again. Just too many variables there to really say. That's not testing, that's guessing or what I call perceived sharpness.
Take that same blade sharpened the same way and run some tests on it removing the variables and one would have a very good idea how it should preform. Take 10 blades and run that same test removing the variables and one could predict how the blades should perform.
But then nothing is written in stone or 100%, that impossible to say as nothing is ever that precise, we are human in the end.
All we can do is play the percentages of what should or could be, throw in the human element along with opinions and bias and anything can happen.
