HeavyHand, You've said a lot ! In your first par. are you saying you've tested all 8 steels sharpened coarsely and fine ? Then drew conclusions ! That alone would take sometime . Then if those 'other' steels preformed better with a finer sharpened edge, then how fine ?...
DM
Yeah, I did a test a while back involving Aus6,Aus8, 154cm, 14c28n, and VG1, as well as side by side tests with just Aus8 and VG1. The fine edge was what came off my fine Arkansas and followed up with a Franz Swaty hone - painfully time consuming but "hair whittling" sharp though not quite what I can now get from my translucent Arkansas and CO strop. Coarse edge was from a 60 grit SiC stone. Right off the bat the 154cm, 14c28n Sandvik, and the VG1 didn't take a coarse edge that well - it just didn't feel or look like the grind on the stone was "imprinting" in the steel like it does on the Aus and 440c steels (IME Buck's 420HC is one of if not the best steels for a coarse edge followed by 440c and then Aus8). This jibes with what I found doing side-by-side with two CS Voyagers, one Aus8 and the other VG1. The Aus8 took the edge better and held it far longer than the VG1 (I almost sent it back to CS with a nastygram). However, the VG1 takes a better fine edge and it lasts longer than the Aus8 by quite a bit. I
have not tested VG10, but from the number of folks that have reported chipping on ceramic hones with this steel, I have to assume it won't respond well to large-grit media. This could very well be one of the reasons so many people have nothing good to say about coarse edges in general, the steel they're using might not be conducive to it, and the stone they're using might not work well for it. I've never used the DMT 120 grit, but for a lot of "fine-edge aficionados" this stone is probably their only coarse, doesn't seem to do a very good job for this application, and they're probably trying it out on some very ceramic-like steels. The ability of the steel to cleanly accept the grind pattern, and the media to present a good grind, is essential to good performance IMO. The other factor in addition to these, is that for a lot of folks "coarse" can be as fine as 600 grit - not very coarse in my book.
Heavy, In your 2nd par. where you say, "a fine edge can just be stropped a few times and put back into action". A few times . How many is this ? Some real numbers will help . Say, the coarse edge cuts 1200 cuts on sisal rope (an abrasive material) and the finely sharpened edge cuts 400 . The both are dull . Now, you strop and neither will cut as much as on the first time . But one started out cutting only 1/3 as much . So, after you strop it 3 times you've cut as much as the coarse did on the first sharpening . Give the coarse edge the same little touch up and you come out ahead still . Which I have to return to the stone anyway after that many stroppings . During my tests I found the strop helped, the stone helped more . DM
I've never done exhaustive tests on the two in side-by-side endurance tests, but from a personal use standpoint, I have to admit I agree with this pretty much completely. Since I haven't done any real testing re true amounts of metal removal, I have to give it some benefit of the doubt.
Any Cal said:
I have noticed that with fine edges, I can cut many feet of cardboard with little added effort, though the edge will no longer shave. With a coarser edge, the length of cut is reduced considerably, and soon binds in the cut. It is my theory that it is due to the better geometry of the fine edge, since it is finer and has more support behind it.
I think some of this has to do with edge bevel, and like I said earlier my experience is that a coarse edge tolerates abuse with acute edges far better than a fine edge. I will admit, when it comes to cutting cardboard a fine edge will do it with less pressure, at least initially, but then I also said I believe that for every material there's a better edge. It could be that for cardboard a fine edge is better, but then again I still believe that the coarse edge will outlast the fine even in this case if the test were run for a long enough time frame. At the least, the coarse can be used to saw back and forth when it will no longer cleanly draw cut. No such option with the finer edge when it dulls.
This convo could go on and on, but I'm going to try and confine it to a simple discussion about stropping techniques for a coarse edge. When I get around to trying out the 120 grit I'll be sure to put it back up on this thread.
Thanks to all
HH
