Yeah, I did a test a while back involving Aus6,Aus8, 154cm, 14c28n, and VG1, as well as side by side tests with just Aus8 and VG1. The fine edge was what came off my fine Arkansas and followed up with a Franz Swaty hone - painfully time consuming but "hair whittling" sharp though not quite what I can now get from my translucent Arkansas and CO strop. Coarse edge was from a 60 grit SiC stone. Right off the bat the 154cm, 14c28n Sandvik, and the VG1 didn't take a coarse edge that well - it just didn't feel or look like the grind on the stone was "imprinting" in the steel like it does on the Aus and 440c steels (IME Buck's 420HC is one of if not the best steels for a coarse edge followed by 440c and then Aus8). This jibes with what I found doing side-by-side with two CS Voyagers, one Aus8 and the other VG1. The Aus8 took the edge better and held it far longer than the VG1 (I almost sent it back to CS with a nastygram). However, the VG1 takes a better fine edge and it lasts longer than the Aus8 by quite a bit. I have not tested VG10, but from the number of folks that have reported chipping on ceramic hones with this steel, I have to assume it won't respond well to large-grit media. This could very well be one of the reasons so many people have nothing good to say about coarse edges in general, the steel they're using might not be conducive to it, and the stone they're using might not work well for it. I've never used the DMT 120 grit, but for a lot of "fine-edge aficionados" this stone is probably their only coarse, doesn't seem to do a very good job for this application, and they're probably trying it out on some very ceramic-like steels. The ability of the steel to cleanly accept the grind pattern, and the media to present a good grind, is essential to good performance IMO. The other factor in addition to these, is that for a lot of folks "coarse" can be as fine as 600 grit - not very coarse in my book.
