David Martin
Moderator
- Apr 7, 2008
hard, Do you mean, fine grain means 'lower' than 5 on the scale ? DM
Not nearly as clearly written/ explained as some other writings . I read it several times over the span of two days and still could not really grasp some of the points . However, try using the muscle side of the leather out as a strop . This tends to get into the micro-serration divots better knocking off those pesky burrs . It worked for me sharpening at 100grit . Still, the technique of the sharpener is a big asset in burr removal when sharpening on coarse stones . As I've read of guys getting great edge retention sharpening their edges coarsely and never even use a strop . Whether we can determine how this is happening in this discussion or not it still remains present . Then I'm positive the type of steel has an effect on this to some degree . DM
Again, I agree a Norton coarse/ fine SiC stone offers good value and a very good edge . Perhaps not the 'best' but what does that 'best' cost you ?
DM
Now, tell me what your meaning by a 'fore and aft' stroke . Is it both a push then a pull stroke ?
Yeah, I'm kind of at a loss. I figured I'd get some change, didn't expect it to be quite so dramatic. My usual edge with this grit is barely capable of knocking a few arm hairs off. On the other hand, it probably doesn't perform like a coarse edge aught to at this grit either. Edge retention will have to be determined later, as well as the ability to refresh the edge with the black emery strop.So, you think the stone is about 200 grit and after stropping on black emory cloth/cake the scratch pattern left looks to be 600-800 grit and it cuts about like it as well ! Interesting .
I've not stropped on that material . Cutting sisal rope is a lot like cutting wiskers . The fine edge does cut nice at first . I could push cut but just go ahead and use the same cutting stroke as normal on all so everything is equal . I fail to see much difference in the two type cutting . As far as efficient use of energy and the movement type throws more of the edge surface into the material being cut . So, you don't get wear just at one area . Also, the D2 steel has 1% V in its mix which is supposed to really help with edge retention . Will that be enough to combat the coarse edge of 440C and enhance its own fine edge ? I don't really know . Thats what will make this interesting . I won't be back home until the weekend . DM
Understanding how different metals and abrasive interact with each other is probably the most difficult aspect to grasp. I've been trying to figure it out myself for a few years now and have a decent idea but with all the steel and stone types its a deep rabbit hole.
Somewhat off topic but, don't you find using a coarse stone all the time that your removing excess metal making blade life shorter? For me its one of the aspects of using a fine finishing stone, I'm only removing metal that needs to be removed preserving the bevel geometry and extending blade life.
What's your take on it?
