W. Andyrsen
Basic Member
- Jul 29, 2025
Grain structure is more important than hardness (within the confines of this discussion.) Same steels at the same hardness can have different microstructures.
I don't see your logic here.To put things in perspective, Carothers makes batches of lets say 20 -100 knives and they list an exact HRC or a range of 1 point from what I've seen.
I'm guessing this is a very modest operation compared to the larger knife companies.
How is a small shop getting more consistent results? Maybe they put more effort into the product and QC than into advertising, etc... ????
That would be a FANTASTIC shot, if only the clips were mounted on the correct sides…
Carothers smallest and most recent offering to my knowledge is their EDC 1.2, it had a cost of $400, not sure if that included tax and shipping. So the price is comparable. And it’s full tang with a 3” blade. So roughly 7” of the higher cost steel.I don't see your logic here.
Smaller profuction means less variance and less amount of work to put into the quality control. Carothers knives are not exactly cheap neither. Each of them is as expensive as a custom made-to-order.
Mass production companies can't always test 1000s blades at once due to time constant. Mass heat treatment also gives different results even in the same forge. The different placement of the blades and heating elements can all play on the final quality. Naturally to make money out of mass production, you have to sacrifice the quality somewhat. Otherwise, mass production is not as easy as it seems.
It seems the consensus is that the tolerances of 58-61 is acceptable to most guys here, so be it. Appreciate the banter
My current EDC is a Demko AD 20.5 with a MagnaCut reblade by Transparent Knives treated to 54.8.
No. Brian pushes the limits on the blades he does. Hard, thin, and hollow are the name of his game. I think the one I have measures out at 0.06” behind the edge.Is this a typo?
Huh, I was unaware. I'll have to take a look.No. Brian pushes the limits on the blades he does. Hard, thin, and hollow are the name of his game. I think the one I have measures out at 0.06” behind the edge.
He has some in his archive that have come out over 55.
Having put various knives at various (tested) HRCs through everyday use, I have to say I definitely notice increased hardness. My current EDC is a Demko AD 20.5 with a MagnaCut reblade by Transparent Knives treated to 54.8. In comparison, I own knives in MC treated to 63, and another to 61-62. I’ve used and sharpened them all. While I’m not going to complain about what I choose to buy, there is definitely a noticeable difference. I’ve also had knives in “premium” steels with such bad heat treats that they lost their edges after a single cardboard cut. Unlisted treatment and hardnesses. That is unacceptable in my books.
That is correct, not sure why I misread the numbers that badly.I think you might want to recheck those numbers. Neither 54.8 nor .06” BTE are acceptable results.
I don’t think many people think in terms of ‘thousandths of an inch’, and maybe you’re one of them, but .06” is nearly 1/16th of an inch (.0625”). Most knifemakers wouldn’t leave an edge that thick BEFORE heat treatment, and 54.8 RC is nothing short of abysmal for nearly any modern knife steel.
Perhaps you mean 64.8 and .006”?
I'm gonna keep the original post the same so hopefully some folks can get a good laugh out of my goof.![]()
