I use a regular electric grinder myself. I'm presuming its very basic as I picked it up from bed, bath...is there a subjective difference in taste with hand grinding vs the machine? I've noticed what primitive describe this morning. I think and only think and aren't certain about it but the tablespoon measure and amount of water used all being equal... When I grind the beans super fine it will taste more bitter vs when I don't.
I switch between a home espresso machine a breville I think and a regular Mr coffee drip.
As long as the hand grinders have good burrs and the other important factors they can compete with all of the top end expensive electrics. Examples are the HG-1 and the Pharos, which are capable of competing and beating all of the Uber Titans.
Hand grinders positives:
Depending on grinder it can make the same quality as the expensive electric grinders,
Cost is a lot less,
Lightweight, small dimensions, and portable,
Less expensive,
Grinds slower,
Good for single dosing,
Sometimes easier maintenance,
etc.,
Hand grinder negatives:
Learning curve,
Demands more patience and strong arms,
Takes more time to dose for bigger groups of people.
Less stable,
Static, might have to spritz the beans with water before grinding,
Maybe clumpiness, might have to stir the grounds before placing in the porta filter,
etc.,
The hottest full size hand grinder right now is the HG-1. Its has 83mm flat burrs, weights 30 lbs, and costs around $945.00.
The hottest portable hand grinder is the Orphanespresso Pharos. Its 8" tall and 6.5" diameter body, 68 mm conical burr set, 5 lbs., $245.00.
Coming soon, the hottest compact portable grinder will probably be Orphanespresso Lido 2 because of the Lido 1 success. 40mm conical burr set, 13" tall and "2 diameter, 3.5 lbs., $175.00.
Because these hand grinders are very popular and are not mass produced it makes buying one almost as difficult as buying a LE ZT.
All of the Uber Titans start on sale at $1800.00 and goes past $3000.00.
