Cold Steel GI Tanto Video Destruction Test Completed
Cold Steel GI Tanto Test completed.
Cutting: I started with an orange. It made thin slices with it's fairly thin edge
I peeled an apple with no problems for a knife of this design this was very easy to do. I cut some cardboard with ease. The thin blade did not wedge in like a thicker knife would.
Batoning. I had a little trouble with the first 4x4 then I increased the hitting force and quickly split
2 more into 4 pieces each.
Chopping: not a fantastic chopper for size but better then the Buck Nighthawk and the Strider BT not as good as the A1.
It took some heavy swings and some energy to get through one 2x4
Tip: I stabbed and tore a hole through a 2x4 easy I did a second 2x4 with the same results. After inspection. The tip had Broken off. The tip on the GI Tanto is very thin. Since the tip broke I did not proceed with the sheet metal
test.
Concrete: The sparks fly, I dented the edge but no chipping occurred. The concrete I was using has very large rock in it. and make it difficult to chop very deep. I used the 3 lb Steel Mallet on the spine finally split the Slab about 14 inches wide. There is only denting and no chipping at this point. Not bad so far.
Concrete: I hammered the tip into the concrete breaking it into small pieces. Many, many pieces no further damage occurred to the knife. Very cool.
Hammering Spine: I hammered the back of the spine throwing sparks cutting into a 2x4. The GI Tanto has no fear of hammer impacts.
Flex: I first hammered the tip into a 2x4 1.5" deep placed in the vive. I begin to flex the blade. I gave it all my weight and power. The GI Tanto flexed to a very sharp angle many times and went back to true almost. I removed it from the 2x4 and clamped it in the vice about the same depth. Again I put all my weight and strength into it. The GI Tanto took some major angles and did not break. I moved the blade up in the vice and still after some good angles broke a section of the tip.I continued again and broke another section. Still no total blade failure. The GI Tanto took some major angles. I didn't have a scale set up but you will see it very clearly in the video.
Metal on metal: I hammered the edge into to a 1/8" thick piece of angle iron cutting a notch and bending the angle iron. Still no chipped edge. I hammered the edge into a 1/8"x2" piece of steel flat stock, cutting all the way through it. Still no blade failure and no chipping. Very impressive. I moved up to a 1/4" thick piece of angle iron hammering the hell
out of the spin. Finally I tore out a piece of the edge. Still no blade breakage.
I hit the back of the spine many times hard on the vice and the blade finally gave in.
I hammered on the side of the tang very hard breaking a little each time. Before I Called the test complete.
Overall: The GI Tanto took some major punishment more than any knife so far and it only cost me $15.65 The cord handle almost completely came off but it can be re-wrapped if needed. One Hell of a knife for the price and certainly worth much more then the asking price.
The videos are in 8 parts. This is a long one.
Videos are posted on www.knifetests.com
Enjoy The Videos They were made for you. :thumbup:
This is so awesome. I watched your Ka-Bar USMC destruction video also (I had always wondered if those knives were as great as a lot of people think they are).
I've been looking for a good, all-purpose fixed blade knife to put in our emergency kits. Something that can take a lot of abuse and still be useful. Looks like the Cold Steel GI Tanto might be a good bet. :D
I have the dial-up, so I appreciate your written description of the knife test, Noss4. Has something for everyone: Flying sparks, cut metal and chopped wood, and a destroyed Cold Steel knife.
That's a lot of abuse for a $15.65 knife. I wonder how much more a $17 knife could handle.
Yeah, it would be interesting to see how much pain the A1 can take. Or the F1, for that matter.
Your welcome gentlemen . :) The GI Tanto is one knife everyone can afford to use, abuse and lose.
just seen the vids and its nice to see you had fun testing it. :D
I like the way cold steel knifes look and i might get a GI tanto, if it does not look to much like my recon tanto.
somehow it made me curious and I'd like to see more cold steel knifes endure your tests.
after i seen the bushman tests i just had to get one hehe.
still need to mod the handle, but i seen nice topics on this forum for that.
keep it up :thumbup:
Nice work again Noss! I didn't think it would take all that punishment. Then again, 1050 can take more abuse than ats, s30v. Seems like the GI Tanto is an amazing bang for the buck.
After viewing the test I searched the web for G.I. Tantos & everyone was out of stock. The Cold Steel site said that they are out till the end of June. Bummer!! I like the looks & now I know it is one tuff knife! it will go great in my B.o.b. & one in the dash of my Jeep!
Zylon: It was fun to test. It's always fun to destroy different objects with a tough knife.
greens:Thanks, It's one hell of a deal for the price. :thumbup: 1055 Steel is supper tough stuff.
Tim the Slugman: I checked ambient weather.com where I bought it. It is out of stock there also :( and they raised the price to $17.39.
I was sure glad I ordered & recieved SIX of them while dealers (2 different dealers) had them. I'll keep a couple, and have the rest on hand for gifts. At less than $18.00, they are super.
My hands are quite large, at 6-2 & 210. In the pic below, all I did was re-wrap the handle to make it thicker with alternating paracord, and substituted a Spec Ops sheath. The sheath that comes with it is pretty "basic".
The other 2 models will NOT fit in a Spec Ops sheath, they are much too wide. You might get an idea from the second pic showing all 3 models. I modified the WARHEAD (on the far left) sheath a bit to allow paracord to be attached easily. Just burned a few small holes in the sheath to allow the cord to stay in place, plus one for a tie down, which it didn't come with.
I might strip one down, put some "fancy" handle material on it. Go back to my old plant, and machine some small saw serrations in the top. If I do, I'll post some pics.
Now we know why we can't find one in stock JGarth ordered them all :D
I'm searching the net I want to get a few more myself.
Noss, thanks for continued tests on blades of all types. I think what this particular test shows is that many of the so called wonder steels have nothing over simple carbon steels in many aplications.
It would take hardly any work to add shock absorbing handle scales tomake an inexpensive knife much better still.
Mike
Noss,
When you tire-kick .... all you get is sore toes ....
OR.... $$$ talks, and BS walks ......
Good luck finding one right now.
T, email me your address, I'll send you one for doing the test.
Let me know if you want the handle re-wrapped like I did to mine...
JGarth
JGarth: nice looking set. Great job on the handles they look much better then the original wrap it comes with. Nice job also on the sheath modifications. :thumbup:
Sure I'll email you. Thanks for the offer.
Mike The Money Maker: Your welcome. So far the basic 1095 1088 and 1055 steels have shown they are fine steels for heavy work knives and their inexpensive. A good combination. All these steels are very tough and durable. I have tested more 1095 so far and it is been very consistent in the tests. It is very chip resistant, shock resistant. It can take a pounding if one needs to do so.
