From my understanding, s30v, Elmax and CPM3V are all tougher than Aus8a, so which one is tougher? If you want the toughness of a fixed blade, get a fixed blade. You won't find "fixed blade toughness" it in a folder... not even cold steel's "super duper tri-ad lock" makes the recon 1 like a fixed blade. If you are putting that much pressure against the "failure" direction of the lock, you're doing something wrong. End of discussion. If you actually cutting with the blade, you will not be applying pressure to make the lock fail. The ONLY way to put pressure in the wrong direction would be to spine whack the knife. Don't be stupid and spine whack your folder...
Strong opinion, but all the talk of lock strength is asinine. The lock is there to keep the blade from closing in on your hand during cutting operations, not to allow you to hand from your freaking folding knife from the side of a cliff. Mild batoning can be accomplished with almost any knife, folding included... you just have to be smart about it and NONE of it includes the lock. If you decided to apply pressure to the lock while batoning(downward force applied to the handle while lock is engaged and blade is stuck in wood), you will eventually damage your knife... yes, even the recon 1.
