nozh2002
BANNED
- Jun 9, 2003
now how does cpm m4 compare to all of these steels. Like zdp 189, cpm s110v and cpm s90v.
See my test results... ZDP-189 clear winner, but best steel is Dozier D2.
Thanks, Vassili.
M4 has outstanding edge retention and toughness. It isn't stainless though. Not even close to stainless.
Thanks, Vassili.
zdp 189 is the best super steel out there.
s110v is over the top and a bit silly if you ask me.
can you please post the link for it?![]()
i'm glad you asked:
Adamantium is created through the mixing of certain chemical resins whose composition is a united states government secret. For eight minutes after the resins are mixed, the adamantium can be molded into a particular shape as long as it is kept at a temperature of 1,500 degrees fahrenheit. After this brief period the process of creating adamantium is completed. The extremely stable molecular structure of the adamantium prevents it from being molded further, even if the temperature remains high enough to keep it in liquefied form. Only a device celled a molecular rearranger can alter the form of hardened adamantium.
Edgepro molecular rearranger anyone?
I'd be willing to bet most, if not all, forum members would not be able to tell any difference between any of the steels listed in the OP if it were possible to come up with a set of identical blades in those different steels. They're all pretty high end.
Ok, I'll ask, silly? Can you really be over the top with high end cutlery steel?s110v is over the top and a bit silly if you ask me.
i'm glad you asked:
Adamantium is created through the mixing of certain chemical resins whose composition is a United States government secret. For eight minutes after the resins are mixed, the Adamantium can be molded into a particular shape as long as it is kept at a temperature of 1,500 degrees Fahrenheit. After this brief period the process of creating Adamantium is completed. The extremely stable molecular structure of the Adamantium prevents it from being molded further, even if the temperature remains high enough to keep it in liquefied form. Only a device celled a Molecular Rearranger can alter the form of hardened Adamantium.
edgepro molecular rearranger anyone?
I haven't seen any initial reports of those using S110V coming in with edges chipping out, or complaints of brittleness....but is more brittle (S110V), and therefore is too brittle imo.
I could if i could sit them in salt water over night.
Is this just speculation on your part based on S110V's composition, or is it your perception/reality based off of other Crucible steels (S30V, S60V, S90V}? Have you in fact run into brittleness issues with S110V?
First, hello to the group. I have posted in the Kershaw subforum, but not here, so "hi" to everyone. I have spent a lot of time reading the forums here, and just like all the forums on every subject (I participate in a few) people can get offended easily.
If I am not respectful enough of someone's favorite knife, manufacturer or model, I apologize in advance.
Knives are tools to me, and I work 'em hard. I have been in construction for almost 35 years, and my knives have to fill a lot of tasks during the day. I appreciate a pretty knife and have a couple, but mine for the most part are users. Like most here, I have the standard shoe box with Case, Puma, Benchmade, Queen, Kabar, Browning, etc. All of them (except the tiny little Kershaw I keep to remove splinters and cut my cigars) are job site (and some camping and hunting) tested.
Generally speaking, my knives cut reinforced nylon strapping tape, "trim" boards, scrape, cut, slice, and punch holes into things I need to have in operation in a hurry. I know that some of the things I do with my knives are borderline abuse, but since I think of them as tools, sometimes they have to go above and beyond expectations.
This brings me to the Shallot 110V. I absolutely can't say enough good things about this knife and about the steel. The knife lays flat enough that I can put it in my jeans AND put on my tool bags without any discomfort. I have only had it a month or so, but so far no rusting, which is huge for me since I sweat like a pig. I have tried a lot of different steels but I always wind up with AUS6 or 8, for no other reason than the fact they don't rust in my pocket. Some of the AUS8s aren't bad, but the AUS6 isn't good except for my pen knife.
The real corrosion test for me and the 110V will be when the thermometer hits the 100 degree mark, which it does every year here in South Texas. Usually for 2 -3 months at a time. Then I will have definitive proof of the steel's corrosion resistance.
The edge holding of this knife is incredible. Actually, almost unbelievable. I reprofiled the edge as it was not as adept at slicing materials as I wanted it to be, and it has made this my favorite EDC. It was sharpened by me once when I got it, and then after only touched up after I dropped it on a concrete slab and it managed to hit the cutting edge right on the belly. No damage to the knife, it just rolled the edge over.
You will find the S110V blade to be thicker than that of the other Shallots in the line, why I don't know. But, I love the thicker blade. Since it keeps the overall dimension and appearance of the Shallot line, the thicker blade allows you to put a double bevel on the edge without getting too thin behind the cutting edge.
I started the reprofile with my large chef's diamond hone. I buzzed the steel right off. Talking to a friend of mine that makes knives, he told me to try the Lansky sharpener I have on the blade.
Roger at knifeworks told me the same thing. It worked like a champ.
I reprofiled with the coarse stone. Cleaned up the edges through the next grits, and the stopped at the fine stone, which I believe is 600 grit. This steel is so hard the 600 polishes it nicely. I polished the very edge with a 1200 grit ceramic, and the steel looks like it hair sized mirror stripe on the edge.
Total time to reprofile on the Lansky including final edge with ceramics was a little under an hour. Well worth the investment or time as I now know two things: 1) it isn't hard to sharpen and 2) I can see how the edge I like performs on this knife.
So far, I couldn't be happier. In fact, I will be buying another one just like this next week to keep aside when this one sprouts legs, or is finally torn up. I hope it isn't for a long time. I have a hard time finding a knife I really like, but this one is a winner.
Robert
