- Aug 6, 2007
So, I cast the concrete for my PH base, and everyone keeps telling me "let it cure let it cure! Let it cure for atleast 20-30 days!". I have to wonder, in this situation of the concrete being cast inside a steel box, exactly what problems might I encounter if I set the hammer on and ran it in only say, 5 days? Unless I misunderstand, which is very likely as this is only the first time I have ever worked with concrete, there shouldn't be a problem as it is cast into the box? I would understand if it was a slab or sidewalk not enclosed on 5 sides, it might be likely to crack like a cracker if pressure is applied on top but this is held tight in the box like a muffin in a pan. What problems could I encounter? The block itself is already solid, and lack of heat on the outside means the chemical reaction has stopped (?). I cast it all at once on Saturday, so now it has been 4 days, AND NO, I am not just being impatient
I just would like to know more about concrete and why everyone says something when logic seems to allude to something else, which in knifemaking and I think everything else doesn't make it true.
