- Feb 17, 2007
Scottickes. What machine the hub to 1.124" on both sides and only go .312 deep and get 2 of the bearings mentioned by Rob with the c3 clearance deal. Then press a bearing into each side of the hub. Then make the shaft with 1/2 NC threads on the one end that threads into th tool arm then a shoulder the is wide enough to position the wheel the correct distance from the arm when the threaded side is tight against the arm and the shaft side is against the inside race of the inner bearing then the shaft is 1/2" or whatever the correct size is for the R8-2rs-c3 bearing. The smooth part of the shaft drop to 3/8 and be threaded NC at the outboard side of the outboard bearing, Then I could place on a thick washer like collar 3/8 id and slightly large OD than the inside race of the bearing. Then when the wheel and bearing assy if on the shaft I would slide on the collar and thread on a nylock nut. The bearings would be press fit and trapped between the shoulder and the collar. The wheel would be trapped between the 2 bearings outside race. Removing that amount of aluminum on the very inside of the wheel should not affect the balance. If I was not completely true with my machine work I would have to turn down the outside or the wheel to make it true. That would affect the balance, I would need to remove a corresponding amount of aluminum 180 degrees from where I removed surface material.
How are regular contact wheels mounted on bearings and what is the bearing number. My tracking wheel and 2" wheels on my platen attachment all use 2 bearings each marked R8RS with the exact dimensions of the bearing above. Their "shaft" is simply a 1/2 bolt. The head rides on one side and and the other side just has a nut up against the inboard bearing, then the remainder of the threads are threaded into their positioner piece. Simple and they must spin far faster than a 10 inch wheel.
Thanks again for everyones input.
