In my mind
When I bought a knife, any knife, I like to know the knifes performance. The producer of the knife have give the knife a ultimate sharpening angle, the best sharpening angle for just this knife, the steel quality and so on.
To have a possibility to learn to know the knife, I must use the knife a lot to find out how it performs. When I use it, it starts to get dull. When it gets dull, its performance changes a little.
So, I sharpen the knife in the exact same sharpening angle and continue work with the knife, still trying to learn its performance. This take some time for me to do, and I must sharpen the knife some times during this test.
After some time, I have learn how the knife performs. The knife do things I like it to do (not what the knife like to do). When I know its performance, I can start to change the sharpening angle on this knife so it fits better what I like to use the knife to do. Sometimes big changes, some times very small changes of the edge.
The main thing is that I first need to know the knife, after that, I can change it, if it needs to be changed.
When I sharpen a knife by hand, I also change its performance because I can not perfectly hold the sharpening angle there is on the knife. That also means that I have no possibility to learn its performance because the edge on the knife change a little every time I sharpen it by hand.
For some this can seams like precision thinking, and yes, it is. Some work I do with my knifes needs this. In that case, I am a perfectionist. In other cases, I do not really care so much if the edge have 22 or 24 degree sharpening angle or if the edge is perfectly straight - or slightly convex.
The main thing is, I like that the knife shall do exactly what I like it to do, every time I do it. To reach this, I first need to know the knife and how it performs. When I know this, I can also change the edge (and the performance) so its fits my needs.
To change a knife before I know how it perform seams to me a little odd because if I do not know how it perform, why change it?
Sometimes when I meet people and we talk knifes, I have notice that there is not so many people that really know their knifes. They just use them, sharpen them, resharpen them, grind them, call them names and ask me why the knife do not work as they like it to work. My answer is the same, you must first learn to know your knife, and then you can change it. When you, after this change, find that you like the knife, hold that edge in exactly the same sharpening angle and your knife performs as you like it to perform.
When I am in the perfectionist mode and talk to a man who is not, there can be some conflicts between us because we use the same words but we have different meanings of the words we use. That can be fun - if we both are in the humorist mode. If not, it can be a hard discussion before we find out what we are argue about.
If a edge is straight, then it is straight for me, absolutely flat (perfectionist mode).
If the edge is convex, then it is convex. If it is convex 0,25 degree or 25 degree = convex. It is not straight, (perfectionist mode).
Example (humorist mode)
You now, what is 1 ?
1 is something between 0,5 to 1,5.
So, 1+1 (0,5 + 0,5) = 1 (can be)
And also 1+1 (1,5 + 1,5) = 3 (can be)
Before we do the counting we must define the value of 1.
If 1 is really 1, its look like this 1 + 1 = 2 (can be)
It is the same with straight and convex edges. Define the different types of edge.
Suggestion: if flat is flat, then everything who is not flat = convex or hollow on edges.
If flat is flat, then 0,25 degree convex is 0,5 convex and 0,5 hollow is 0,5 hollow. If not (humorist mode) then I can change 0,5 convex edge just 0,5 degree down to a hollow edge
or?
It must be simpler to define what is flat (straight).
Thomas
