this doesn't really work on water stones....comes off quickly from..... water, and it's really hard to see the sharpie on a shiny rounded convex. I think your best bet is to listen and feel for the edge making contact with the stone, then work the edge. I start sharpening behind the edge and then catch the edge at the end of the sharpening stroke. You can find the angle by pushing the blade forward lightly on the stone or strop. Keep bringing the angle up until the blade catches. Thats your edge.
You have to be careful to modulate you pressure and angle to get a consistent angle on a strop, though. It's very easy to accidentally broaden your edge angle when using a flexible backing.
Well, that goes without saying but fair enough. I think Marcinek was responding to another member discussing difficulties when sharpening convex in general, as opposed to when out and about specifically.when your chasing the edge on a smooth convex, a sharpie wears off before you find it. The water and material removed from the blade while trying to pinpoint that edge, makes short work of it.....I found sharpies are good for chasing the edge not finding it on a CONVEX, you cant pinpoint a convex edge with a sharpie. This techinique works on a toothy V EDGE in my opinion. Convex is rounded, its all about the feel and follow through technique for me...unless you use a mousepad and paper, which I don't
In the field, it sucks if you can't sharpen your blade because no one brought a sharpie....OP doesn't want to bring out a mousepad either
Easier to hit an apex on a "V" as opposed to on a "U" . In a field or in your room it don't matter.
New users of a sebenza will disagreeActually, the very opposite, for reasons I detailed earlier.![]()
Sounds to me like you are comparing putting a microbevel on a convex in the field vs trying to sharpen a V edge without a micro. Let's compare microbevel on convex vs micro on a V edge. The answer is an obvious one.Nope. If anything, a convex is faster and easier to maintain than a flat edge of equal angle (in the context of field touch-ups) because it's going to be easier to hit just the apex. Think of a convex as being like a series of grinds that decrease in angle as they move back from the edge. Your stone will only be sharpening (rather than shaping) if it's hitting the apex, and even the slightest bit too shallow on a flat means you're contacting the shoulder rather than the apex. On a convex, that shoulder has already been ground off and your contact point is more likely to be pretty close to the edge where the abrasion may work down to the apex itself and then cause actual sharpening abrasion. Freehand sharpening in general is not going to be perfectly flat, so you're already making a convex.
Maybe i somehow missunderstand your post?
Its almost as if you are comparing picture on the far left with the one on the far right. But what i say is take that picture on the far ^right ^ and draw a V inside of it. ( Connect 3 corners with straight lines). Now let's compare...
A convex edge has more meat behind the apex (that's the whole point of having one) so before i get to the shoulder of a V there are already plenty of the compound grinds on a convex that get in the way.
maybe I never had a truly dull blade...I can find the apex on my user at home beater axe. On a dull convex blade you should catch the apex of where the convex start to dull/flatten. This is where I figure you start working the edge until you make it the the true apex. The weird thing about a convex edge, is it can feel dull on your finger but slice right through newspaper.....maybe its not even dull and all you have to do is use itEasier to hit an apex on a "V" as opposed to on a "U" . In a field or in your room it don't matter.
ditto
all you have to do is strop the convex edge on a palm sized leather strop pre-loaded with sharpening compound (or even back of the leather belt that has some compound on it will do) and your knife will be sharper longer than you will be able to survive in the wild![]()
