His laundry list of the evils of factory knives are easily neutralized if not completely destroyed. Than again, since when are knife makers/knife nuts any wiser than the general public?
There doesn't seem to be any clear authority or body of knowledge (like a real science of cutlery). I've seen some fledgling efforts, but no real locus of authority on these types of issues. Outside of engineering, it seems to be a largely "art and craft" approach, with experts differing sometimes on very fundamental things. Still, put ten economists in a room and you might get ten different answers.
I have quoted from some of them and heard back from other experts or people who have used something successfully that they say shouldn't work well at all. Some, for example, have said that thick blades should not cut well, whereas they simply might not cut as well as thin blades of the same material. But you can do things with blade geometry to make them cut better than you might have expected. Or, that knife blades other than stilettos are not made to pierce or penetrate.
I've found this FAQ on blade geometry helpful, but there are things in there I'm sure some here would disagree (like how difficult it is to touch up a convex blade!).
http://www.knifeart.com/bladgeomfaqb.html
Here's a sample concerning an issue I remember doing a search on here a while back. Opinions here and in other forums were all over the place, and sometimes it was the experts disagreeing with each other the most:
[FONT=arial, helvetica]
"Blade thickness or thinness is important to both strength and cutting ability of the knife. A thick blade will generally be stronger. But a thin blade will generally have a thinner edge -- and thin edges cut easier and better. So the choice of blade thickness is driven by the compromise of strength vs. cutting ability, just like the choice of point type.[/FONT][FONT=arial, helvetica]
Once the blade thickness is chosen, the particular grind type (see below) can reinforce the attributes of that thickness, or try to make up for any weakness. For example, on a thick blade, a flat or hollow grind can be utilized, so that even though the spine is thick & strong, the edge is thin and cuts a bit better than expected. Or on a thin blade, a sabre grind can be used to make the edge a bit stronger than it would otherwise be. Of course, the grind can reinforce rather than counteract the blade thickness.[/FONT][FONT=arial, helvetica]
"[/FONT]
