I think one of the stumbling blocks here is thinking that straight lines and curves are different things.
In fact a straight line is just a special example of a curve. Straight lines form a subset of curves.
Extra credit for a Venn Diagram.
Actually, in the most technical sense - the mathematical one - he's wrong. Curves meet at angles.
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=curves%20meet%20at%20angles
I am surprised we are assuming Euclidean Geometry! What if the space-time continuum is curved? I think if we were to calculate the geodesics of the space-time continuum then we would find the perfect edge geometry. A geometry so keen that it has the ability to cut into space-time itself, thus releasing a blast of tachyons and propelling you into the future.
- T
To the OP in plain Speak!
I make knives & sharpen them for a living and I find a convex edge to last longer and cut circles or curves better than a vee grind on the same knife.
The one exception is on a straight razor. A vee grind will shave your face better better than a convex grind so how long they last doesn't matter.
See! No math involved!![]()
thanks for thati was just saying that even IF he stuck to that line of reasoning then logically it follows that v edges don't truly have an angle either hehe
that's a half hour i won't get back
To the original poster, go ahead and try that convex blade you might really like it. If not sell it or put a V grind on it. Convex is really easy to maintain.
Looks like all the internet PHDs came out with the charts and graphs makes me want to run get some rubber waders so nothing splashes on me.
Wait. What was the original OP about?To the original poster, go ahead and try that convex blade you might really like it. If not sell it or put a V grind on it. Convex is really easy to maintain.
Well, in a way. I also agree with this statement: "A v edge can be more or less acute than another v edge. And a convex edge can have more steel behind the apex of a v if it has a more obtuse edge angle than the v. "
Again, it's like saying a 2000 pound block of concrete can be heavier than a 500 pound block of velveeta cheese.
Freaking math. Thank goodness I teach a physics based science.
Oh wait, that involves math.
For the life of me, I cannot even begin to understand how people cannot see that two arcs intersect to form an angle that terminates at the apex by two straight lines. Where is Spock when you need him? (RIP Leonard Nimoy)
Convex edges don't have angles. The intersection of curved lines have an "angle of intersection," which, as the formulas show, are represented by straight lines.
I think most of the misinformation in this thread comes from people converting V edges to hybrid convex edges that basically knock off the shoulders of the V edge, improving slicing ability.
But you can convert a convex edge to a V edge and that V edge will be more acute and slice better.
The geometry of convex edges and V edges are infinite. Anything that one particular V edge can do a particular convex edge can also do equally well, and vice versa.
And your point is?![]()
The red line it tangent to the blue curve at point A.
Imagine you draw a vertical line though A and reflect the blue curve and red line across that vertical line.
Then you have a vee grind (the red lines) and a convex grind (the blue curves) that have the same edge angle. And the convex is inside the vee. And thinner.
