Since there arn't many cheap covex blades about, would be ok to practice on an old SAK that I have? I know these dont have a convex edge, but wouldn't the mousepad technique create one? Don't really want to ruin my F1.
I did put some marker pen on the blade, and it looked like it removed 1/8 inch of it from the edge. Is it possible that Im holding the knife at too much of a flat angle, so the pen is rubbing away from the edge, but there is not enough pressure on the absolute edge?...
Buy a carbon steel Opinel (convex grind), give it a patina with vinegar, practice the "rocking motion" described by db. Pay attention to where you remove the patina and you will get it.
dantzk.
Here's my setup. 7-8oz leather glued to hardwood or MDF. Then, wet/dry taped to the leather. I rarely go below the 1000 grit, most of my sharpening (or, maintaining a sharp edge) is done on the 1500 and 2000.
One side:
The same "strops" flipped over:
I generally strop about 10 times one way, then 10 the other. Then I'll go about 5 and 5. Then back and forth a couple of times, once on each facing of the blade. Then strop with leather and green compound (or lately, the white).
Go to Esav's link for "sharpening the BRKT way". THat's the way I learned. After a time, you'll develop your own technique and feel for it.
You should practice any new technique on a cheaper knife first.
