I bought some Corby style bolts from Tracy and want to use them on my next knife. They are medium and have .183" Shaft and .250" Shoulder. What I have tried so far:
1. I drilled the hole in a scale for the shaft with a drill bit a little thicker than .183". Then without moving the scale I changed the drill bit to 1/4" and partially drilled it for a shoulder. There were 2 problems with this approach: a. the hole for the shaft was a little off center. b. The shoulder part was to tight and I could not insert the bolt in without applying a lot of pressure, and by "a lot" I mean I could barely rotate the bolt with a screwdriver.
2. I went to Home Depot and bought a set of step drills. One of them has 3/16" on the tip and 1/4" is a next step. I tried it on several pieces of scrap wood and did not like the result either. In this case the shoulder hole is too loose. I can see a small gap between the bolt and the material which I can fill with an epoxy but I do not like it. What I am looking for is a solution that will give me a nice tight (but to too tight) fit.
What do you guys use and what works the best for you? Any ideas what am I doing wrong?
I see that Texas knife supply has a step drill that might do the job, but they are currently sold out. I watched a Subhilt making video by S.R. Johnson and he uses something similar to this drill, probably just made from a regular drill bit. It looks pretty easy to make for someone who has a lathe and some basic skills to operate it...
Sergiy
Sergiy
