- Aug 2, 2010
Today's my day off and I've been playing around with burning cotton balls. I'm curious as to if anyone has tried cotton balls dipped in paraffin wax? I made some today and I think I've found my new tinder.
I got the idea of Cody Lundin's book "98.6 degrees". He talks about fire starting with several methods. Of course, one is PJ on cotton balls. Then he tells about different matches and said that he dips strike-anywhere matches in paraffin wax to help weatherproof them and make them burn longer.
We all know that PJCB work pretty good, but I hate the mess they make, personally. Sticky, messy, blah.
The thought struck me: "Why not cotton balls dipped in paraffin?"
I decided to fire up the old Lee pot (since it was empty) and melt some wax. After it was ready, I just grabbed a cotton ball with the tip of my pliers and dunked it in the wax. I didn't let it soak, I just dipped it like you'd dip a chip in dip (how's that for a tongue twister? lol).
Then I dropped it on a piece of cardboard and let it dry. I guess that I made about 30 of them. I did experiment a bit, I let one ball just soak in the wax until it was full, and then I took another ball and used it to mop up the little bit of wax left in the pot. It really just had a light coating on the outside of the ball, and it wasn't completely coated.
Then I did a little comparison burn in my mini charcoal grill. It was just bare, clean metal, no charcoal, etc. I used a BIC lighter to light everything. It has been a pretty breezy day too.
An uncoated ball lasted for less than 30 seconds.
I took a cotton ball that I rubbed with PJ and burned it. I probably had a little too much PJ on it, as it took a bit to get it to light. After it lit, I got just under 4 minutes burn time.
Next was the totally filled wax ball. It was so full of wax that I couldn't tear it open with my fingers. So I mashed it flat and picked at an edge to light it. It lit after a second or two and that thing burned for almost 6 minutes.
The lightly coated ball lit extremely easily and burned for 4 minutes. The un-waxed part burned very fast, but when it hit the waxy area, it slowed down to a nice controlled burn rate. I don't think that this one would be very weatherproof, with so much untreated area on it.
The ball with a complete coating and a little saturation lit easily and burned for almost 5 minutes. This should be pretty weatherproof with the completely coated outside.
All of the treated cotton balls (PJ and wax) had a great flame and good burn rate, even with the being pretty breezy.
The wax balls are a little more labor intensive than the PJ, but I totally feel that the advantages out weight the additional labor. You've got to melt the wax, dip the balls, and then let them dry. In use, there's no mess, no sticky fingers or containers, and the coating is less affected by heat than the PJ is. To me, they are easier to light and they also burn longer.
I guess that it took me around 45 minutes or so to do 30 balls, but the majority of that time was waiting for wax to melt. I kept the temp down on the LEE pot to prevent any flash-ups from the wax catching fire. I probably could have turned the temp up, but I wasn't in any hurry.
