- Jul 13, 2009
i domy problem is obtaning aluminum plates that big.
Here you go
http://www.onlinemetals.com/merchant.cfm?pid=17683&step=4&showunits=inches&id=997&top_cat=60
It's not that hard to figure out.
you guys are right i was rude and am seriously sorry maybe i need to be a little less sensitive.
and yes 1234 that makes sense what you are saying about the heat treats on the crucible website
sshepherd i have been making knives for 2 years not very long.
ok then if i am going to heat to 1950 for 1 hour then air quench, does any one know what your initial RC is going to be at? also will plate quenching give me a higher RC?
Since CPM 154 is air hardening it will not make a significant difference if the air temp during the quench. A fan blowing onit will speed things up a bit but don't get too crazy or you might induce a warp. The HRC listed on the crucible website indicates oil quenching varies between 62-64HRC as quenched so air would be 1-2 points lower prior to tempering. That would put you at 60-62HRC then temper down to 58-59HRC depending on what type of knife you are using. The reason it is recommended to send out the CPM steel is that heat treaters have vacuum ovens, cooling systems and cryo set-ups. They have done all the homework and for $5 plus shipping it is hard to justify doing it yourself. But I understand wanting to do it all. But if you are worried about getting the most from your steel I suggest sending it out also.
As the Count pointed out, the data on the crucible web page is mainly for industrial purposes not knifemakers. Since we deal with much thinner cross sections oil can be problematic. You would not be happy trying to straighten out a horseshoe. Good luck and keep us posted on your progess.
thank you everyone for the info
looks like i will not be stainless steel wrapping it because i would like a bit faster quench because i am going to be fan quenching it.
ok i am going to heat to 1425 for 10 mins ramp to 1950 for 1 hour then floor fan quenching it untill cool to touch then dry ice over night then tempering at 550 degrees for 2 hours twice. my aim HRC is 59-61.
