I don't wanna debate INFI "proprietarity", but steel mill making special alloy for maker isn't something unbelievable, for Busse or anyone else...I find it hard to believe that a steel manufacturer makes up a special steel for Busse only.
Or if it does, it will likely only get better.
I was never comfortable talking about "Carbon V" steel because that steel didn't exist. I feel the same way about "Infi".
IMO Busse makes great knives but overprices them by 30% or more. Makes up a name for a steel from the steel catalog, and has a great business.
I prefer 3V over A8 (mod) for choppers for it's greater wear resistance.
Lets drink.
Impurities. Much of new steel today is recycled, and there are 'leftovers' from the prior products.One batch of steel I recieved a few months back had extras like copper and a few things that aren't in the book specs for that steel. Impurities? Tweaks?
Yes it does, this is why you don't use stainless in swords.i would appreciate comments on higher chrominum in alloys like 3v. once you make it high chrominum would'nt 3v be something other than 3v. i also wondered if real high chrominum doe'st tend to make alloys more prone to brittleness.
dennis
dennis
Ah, but what about free chromium? Typical stainless steels in cheaper knives don't really have any level of wear resistance worth noting, but they are still pretty brittle for the most part.Dennis, just about any carbide former will cut down on toughness and edge stability once the carbide fraction gets high enough. 3V has the large, hard vanadium carbides in it for excellent wear resistance but it's overall carbide fraction is low enough to still allow it to be tough, with good edge stability.
3V's carbide fraction is only 5%
S30V's is 14.5% ( very good for such a wear resistant stainless steel, BTW)
S90V is a whopping 23%
10V, though even more wear resistant than S90V has only a 17.5% carbide fraction, so that tells you that carbide fraction isn't the only factor. It's all vanadium carbides, whereas S90V includes chrome carbides. 10V also gets harder, so you get better edge stability, slightly better wear, but no corrosion resistance unlike S90V. Neither are considered tough like the low carbide, simpler steels.
This is just the tip of the iceberg though I'm touching on.
BTW, CPM M4 has 12.5% total carbide fraction which explains it's toughness for a very wear resistant steel. Run hard it's pretty close to the S90V class in wear resistance, with better edge stability. Pretty amazing actually.
Some others:
S125V = 28%
S110V= 22%
440C = 12% ( all chrome carbides)
154cm = 17.5% ( higher than S30V, which has more wear resistance. That's because 154cm is mostly moly + chrome carbides rather than the Vanadium plus chrome in S30V)
HARDENED STEEL 60/65 HRC
CHROMIUM CARBIDES 66/68 HRC
MOLYBDENUM CARBIDES 72/77 HRC
TUNGSTEN CARBIDES 72/77 HRC
VANADIUM CARBIDES 82/84 HRC
taken from:http://www.crucibleservice.com/eselector/general/generalpart1.html
M4 is really about as close to perfection as I've ever seen in a folding knife, with corrosion resistance being the only real downside(I don't really need 3V/A2 class toughness in a folder). I'm thinking that a nitrogen alloy steel might be the answer. It's said that vanadium carbides form easier than other carbides, and so I would think it's safe to assume that the same can be said for vanadium nitrides. With the currently developing powder metal technology these days, it might be possible to make a wear resistant steel with a high volume of vanadium nitrides for wear resistance, while only having a bare minimum volume of chromium for corrosion resistance
I couldn't agree more. :thumbup:If you can't learn something new here everyday you're not paying attention.
Hi Mastiff, do you feel there is a better knife steel than CPM-3V? Seems Fehrman is making all of their knives out of it!
