- Apr 18, 2022
Cpm-3v vs a2 for a forest survival/bushcraft knife? Trying to decide between lt wright gen6 scandi signature edition in a2 or lt wright illuminous 5 in cpm-3v, give me some arguments to which one to get? Thanks!!!
Was thinking of scandi-vexing the edge on any of the 2 knives I get. Would that work?I'd personally not pick scandi grind as it's pretty much only good for carving wood. Pure bushcraft - sure, scandi is good.
But for survival, regular use or anything else - I'd want saber or full flat grind.
Then steel - I doubt you'll break either. 3V should be a lot tougher though.
3V will be more corrosion resistant.
3V will hold the edge significantly longer.
A2 will be easier to sharpen.
So it depends on if you carry a sharpener or not. Every steel gets dull eventually. I'd hate sharpening 3V on a rock, hell, I'd hate to have to sharpen anything on a rock, but I'd rather sharpen A2 on a rock than 3V.
Use would be bushcraft, batoning, carving stuff like itAs above depends on your use and preference re grind/knife shape etc... I'd not have a problem with either and both steels well HTed should never break under appropriate useage.
I've no working blades in Cpm3v (carpentry) but many blades in A2 - chisels and plane blades which do have an excellent HT (Lie Neilsen, Veritas etc...) and all have stood up extremely well under heavy constant use. A2 is easy to sharpen and ime holds an edge very well.
That would be good. Also making the grind bit taller would most likely be ideal at that.Was thinking of scandi-vexing the edge on any of the 2 knives I get. Would that work?
They are priced similar in USA, I'm from eu, where import taxes make all the diffrence, the one in 3v would cost me around 380eur give or take, the a2 300 eur!LT makes pretty good looking knives.
3v is generally considered way better, are they priced similar?
There is stuff locally, but the thing is their warranty isn't good, or it says batoning etc is abuse... pretty much warranty is why I don't want to buy more locally, idk myb you know some eu brands that don't screw you when it comes to standing behind your product. I have a fallkniven s1x, the knife is okay (lacks character, and if it does somehow break, then good luck trying to get it covered w fallknivens warrantyI'm surprised you can't find something similar more local?
Here in the USA A2 isn't as trendy or "Hot/Popular" as 3V.
I think most people Here would pick 3V.........heck, even 3V is losing ground to Cruwear, and now more recently Magnacut. :/
* I like Most steels.
Buy what you like, and what's available. I personally feel handle shape (comfort) is more important
If you are backpacking for a month and it's raining the whole time, and your knife is packed away in a duffle bag, soaked and unused that whole time, ignored.......... It will rust.Does A2 rust that easily? I dont think ive ever used that steel....
Will I buy more A2 knives someday?..... Probably.
Those look Very pointy......Me tooHere is a couple:
Many people use camping knives with almost no chrome at all. A2 has 5%, which is enough that you just need to keep your knife dry when packing it away. Note that 3V has 7.5%.
Lionsteel M5 in CPM-3V for 170€, ANV M73 in Sleipner for 210€ or even TRC South Pole in Elmax for 350€ would be my choices if I were you.They are priced similar in USA, I'm from eu, where import taxes make all the diffrence, the one in 3v would cost me around 380eur give or take, the a2 300 eur!
