- Apr 18, 2022
Cpm-3v vs a2 for a forest survival/bushcraft knife? Trying to decide between lt wright gen6 scandi signature edition in a2 or lt wright illuminous 5 in cpm-3v, give me some arguments to which one to get? Thanks!!!
I've only experienced A2 with chisels and plane blades from companies who I'd guess will have better HT's than most/any knife Co. Karl Holtey certainly as good as you could get and I've always found my A2 blades a pleasure to sharpen and not as you describe.3V for me.
...and I can easily put a better edge on 3V than on A2.
For some reason, A2 (*like D2) always leaves me with a kinda' micro-serrated edge that I can strop a bit to make better.
*"To each his own", "Your mileage may vary", yada, yada, yada.
I've got a Busse Team Gemini with A2 Steel...
I hope you find one: Bro'!Man, I've been wanting one of those for a bit...the "M" version(?).
I've seen 'em come-up in the Exchange, but it seems I'm always behind the 8-ball (*financially) when they appear. I hope to score me one at some point.
I'd personally not pick scandi grind as it's pretty much only good for carving wood.
One obviously never tried to cut potato, onion or an apple with scandi...Lol where did you get this idea? Thats just plain silly.
Mate, you said only good for wood carving. You are aware other knife tasks exist than wood carving and slicing food right? Like thousands of different tasks.One obviously never tried to cut potato, onion or an apple with scandi...
Try it and see. Unless the blade stock is very thin - it'll wedge it instead of cutting.
No. Mora robust for example will struggle with zip ties while being shaving sharp.Mate, you said only good for wood carving. You are aware other knife tasks exist than wood carving and slicing food right? Like thousands of different tasks.
Are you trolling?
Hello brother. First of all I hope you're having an amazing day. I decided to buy genesis in 3v coyote n black g10 mountain finish, its a side kick to my malanika leuku full tang magnacut. As I already had a similar knife to l5 and gen 6 I just opted for the genesis, and decided that cpm 3v would better run in my area, as its wet wet and another time wet. So corrosion resistance was in mindOP, did you decide on a blade? Sorry, guys, I'm a little late to party here but OP brings up a good topic and I have a couple thoughts on this.
First, from what I remember, LTWK runs 3V about the same hardness as their A2. So, really, compared to A2, the 3V is just a tad more difficult to sharpen, may hold an edge slightly longer, and of course, be significantly tougher because of the lower hardness.
Second, the more I use an LTWK in Scandi grind, the more I want to use one on anything outside the kitchen. And the thinner, the better. The Gen 6 is .125" thick w/ 6" blade length and the I5 is .156" thick with a 5" blade length.
So, considering all this, I would go for the Gen 6 any day of the week. I really don't think I could ever even with a reasonable mechanical advantage exert enough force to break the Gen 6.
Curious what the OP decided on....
P.S what you carrying in the woods as your knife? Right now I'm actualy thinking of buying an esee to try, but I have mixed feelings.OP, did you decide on a blade? Sorry, guys, I'm a little late to party here but OP brings up a good topic and I have a couple thoughts on this.
The Genesis is an outstanding knife. It's for sure one of my favorites, and that mountain finish is just icing on the cake. I also like to have a second, larger knife available and i bet that leuku is a pleasure to use. I agree, 3V would be the better choice for corrosion resistance. Nice choices!Hello brother. First of all I hope you're having an amazing day. I decided to buy genesis in 3v coyote n black g10 mountain finish, its a side kick to my malanika leuku full tang magnacut. As I already had a similar knife to l5 and gen 6 I just opted for the genesis, and decided that cpm 3v would better run in my area, as its wet wet and another time wet. So corrosion resistance was in mind![]()
I don't get out much, but I love to spend time with my feet in the woods with a knife in my hands. I recently put down my convex Genesis in 3V to start using this Hidden Woodsmen Puukko in 3/32" AEB-L. I am absolutely blown away by how a thin stock Scandi grind knife cuts through a variety of materials. And, of course, I love to have a BK7 within reach as well.P.S what you carrying in the woods as your knife? Right now I'm actualy thinking of buying an esee to try, but I have mixed feelings.
